need jira customer portal rewrite using nginx
nicolas unterberger November 5, 2014
Hi Guys.
I managed to set up a nginx proxy pass from 80 to 8080, but the problem is i want to be accesible the customer portal under helpdesk.domain.com instead helpdesk.domain.com/servicedesk/customer/portal/1.
I tried multiple rewrites but it doesn't seems to work, the only option that i have it seems to set a proxy_redirect.
What i am missing?
This is my nginx config file.
user www-data;
worker_processes 4;
pid /var/run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        include /etc/nginx/mime.types;
        default_type application/octet-stream;
        access_log /var/log/nginx/access.log;
        error_log /var/log/nginx/error.log;
        gzip off;
        gzip_disable "msie6";
        include /etc/nginx/conf.d/*.conf;
        include /etc/nginx/sites-enabled/*;
        server {
                listen   80;
                server_name  helpdesk.domain.de;
                access_log off;
                location / {
                        proxy_pass http://helpdesk.domain.de:8080;
#                       proxy_redirect http://helpdesk.domain.de/servicedesk/customer/portal/1 /;
                        proxy_set_header    Host            $host;
                        proxy_set_header    X-Real-IP       $remote_addr;
                        proxy_set_header    X-Forwarded-for $proxy_add_x_forwarded_for;
                        port_in_redirect off;
                        proxy_connect_timeout 300;
Norbert Bede December 29, 2015
hi
same issue here. did you found proper solution ?
norbert
nicolas unterberger November 11, 2014
Bump. I can not believe no one has faced this problem before. Where are you, atlassian guys?
