×We have mulitple projects in JIRA and i dont want to manually add a new column in the existing workflow by moving across each project.So is there a way to Globally define the column in all the projects i have.
Currently my scrum board would look like :
To do -->in progress-->blocked-->Done
But now we have decided to add two more columns to all our projects due to business requirements and that should look like :
New-->To do -->on hold-->in progress-->blocked-->Done
Any suggestions would help!Thanks
Hi Nandhini,
To do this you're most likely going to need an add-on such as Bob Swift's CLI. There may be other add-ons out there that can handle this as well.
There is a Suggestion that you can find at JSWSERVER-13137. Please vote on the issue and add your use case to add impact. If that does not match what you're trying to do exactly you can also create a Suggestion on JAC to have this feature implemented.
If you create a ticket on JAC please add the link here so the community can vote on it.
Branden
