In the Issue types general settings, I created a new Issue type named "Test case" as a sub-task. I changed the icon and defined a description.
My problem is the following:
This new issue type is not taken into consideration, I can't create a Test case issue from my project or from the board, or from the child issue creation function. Even in the issue type configuration (in the project) Test case doesn't show up.
Could you please help me out with it?
Ps: I am still in a free subscription for now
Hi @Adrien Sosson ,
Welcome to the community.
Did you add the issue type to the issue type scheme that is used in your project?
