no option to connect dvcs repo in project administration
Suraj Rathod June 6, 2013
As explained in the documentation, I have succesfully configured JIRA and Bitbucket OAuth and am able to see the list of the repos with smart commits enabled from "DVCS accounts" menu option. However I can not see any option in project administration to link my bitbucket repo with the project. All I see is the option for svn repos. If you observe following tutorial : http://blogs.atlassian.com/2012/02/connect-source-jira-issues-dvcs-bitbucket-github/ , it clearly displays the option to connect your dvcs repo in administration menu where as no such option I am able to find/enable. Can you suggest what I am missing in this setup?
Suraj Rathod July 4, 2013
Update : For commits to appear in JIRA (mapped with Project and Issues) we need to follow pattern described in this : https://confluence.atlassian.com/display/BITBUCKET/Processing+JIRA+issues+with+commit+messages
Janet Albion
June 6, 2013
Hi Suraj,
The feature is no longer there since recently we have remove the neccessity in mapping project to repository. From my test it has been remove in JIRA 5.2
-Janet
Suraj Rathod June 11, 2013
Hi Janet,
Thanks for the reply but then how we are going to trace the commits of related project repository code from JIRA? I am not getting how to link and display happenings of project with repository commits in JIRA. I am in the situation where I actually can not say if JIRA and bitbucket are linked as JIRA not showing what is happening with the code. Can you educate me more in this?
-Suraj.
MJ
June 6, 2013
Hi Suraj,
The information in the blog you have linked to is from early 2012, and probably depending on which version of JIRA you are using, not accurate (anymore). Please have a look at this and this page for more information regarding this functionality.
