osuser.xml is not working for jira 4.4 AND User management is not happening against LDAP
Sreenivasaraju P
September 2, 2011
hi,
I am trying to migrate Jira 3.12.3 to Jira 4.4. In our old instance(3.12.3) user management has been done by LDAP.
While migrating to 4.4 , Jira started successfully but i am not able to login to the sytem. It is not authenticating even though I have placed osuser.xml in the 4.4(WEB-INF/classes) folder.
Please suggest, how can use do user management in the 4.4 version with LDAP.
Sreenivasaraju P
September 5, 2011
able to resolve this.
osuser.xml has to placed in WEB-INF/classes folder before restoration. i have put it after restoration. thats why the problem came
Thanks for support
Nic Brough -Adaptavist-
September 4, 2011
The user you've specified as the one doing the LDAP lookup does not have the privileges to use your LDAP. Check the user settings and authentications.
Sreenivasaraju P
September 4, 2011
Trying to configure LDAP user directory,
I am getting the following error, please let me know how can i fix this.
Connection test failed. Response from the server:
[LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, vece]; nested exception is javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, vece
