please help to filter issues in current sprint
Kseniya Nesterova April 18, 2023
I need to write a filter which could support filtering issues created in current sprint only.
I created this one, but it returns 0 results:
project = "NAME" AND created IN ((sprint is openSprints())) ORDER BY created DESC
Sam Nadarajan
Hello @Kseniya Nesterova
The JQL you posted is invalid.
  • The created field requires a date value(s), not another clause, such as what you have in parantheses
  • The "IS" operator only works when checking for the presence/absence of values
  • The "Sprint in openSprints()" will only look for issues where the sprint value has been set to a sprint that has been started but not completed.
If you want to search for issues created in the current sprint, I'd suggest:
project = "NAME" AND created >= {{sprint start date}} ORDER BY created DESC
Since you're taking about the current sprint, you wouldn't need to add a "created < {{sprint end date}}" as you'd be in the current sprint.
Kseniya Nesterova April 19, 2023
It returns me error :
Error in the JQL Query: The character '{' is a reserved JQL character. You must enclose it in a string or use the escape '\u007b' instead. (line 1, character 31)
Sam Nadarajan
Hello @Kseniya Nesterova the {{}} were part of what you needed to plug in, I should have clarified. Your query may look something like:
project = "NAME" and created >= "2023-04-18"
Like Kseniya Nesterova likes this
Thanks, so there is no way currently to make this filter work on something like beginning of activeSprint()
And will require manual update for each sprint moving forward.
For a reference:
https://jira.atlassian.com/browse/JRACLOUD-72007
Bill Sheboy
April 19, 2023
Hi @Kseniya Nesterova
As described by @Sam Nadarajan there is no built-in way to do such a query.  There are probably marketplace addons to support such queries.
What problem are you trying to solve by doing this, and how often do you need to solve this problem?  Knowing that will help the community to offer suggestions.
For example, some possibilities are...
  • Let's assume a team notices they are adding things after the sprint starts.  The team could look at the built-in sprint report to see what was added, and discuss that at the retrospective, considering how to improve sprint planning, focus on planned work, reducing unplanned work, etc.
    • If you wanted to preserve the condition (adding to active sprint) longer, automation rules could be used to detect this.
  • Or...let's assume this is work supporting a project and you want to track scope change.  That could either be done with the sprint report or the release reports to see what is happening.
  • Etc.
Hi Bill, thank you for your comment here. I am working on Dashboard for active sprint and would like to get updated information there every time I open it.
For some of the cases / custom filters that works - using // sprint is openSprints()//
but there is a case there I need to be able to filter Issues in JIRA in = Active sprint time frame.
Bill Sheboy
April 20, 2023
Please take a look at the built-in Sprint Health Gadget. If you add that to dashboard, it will show the scope change during the sprint...and if you click on that value the Sprint Report will display showing the changes.
