I have cretae a python script that working but for only 50 issues.
Can someone help me to modify it because I have 5000 issues to download.
I have try with chatgpt, but withut success :-)
Thanks for your help !
import requests
import base64
from openpyxl import Workbook
from dateutil import parser
import sys
import time
# Redirige stdout/stderr vers un log
sys.stdout = open(r"C:\Users\xxx\Documents\jira_export.log", "w", encoding="utf-8")
sys.stderr = sys.stdout
# -------------------- CONFIG --------------------
JIRA_URL = "https://xxx.
atlassian.net"
EMAIL = "xxx"
API_TOKEN = "xxx
FILTER_ID = "10249"
OUTPUT_PATH = r"C:\Users\xxx\Documents\jira_export_all.xlsx"
MAX_RESULTS = 50 # Nombre d'issues par requête pour rester stable
# -------------------- CHAMPS A GARDER --------------------
FIELDS_TO_KEEP = [
"key","summary","status","assignee","created","updated","priority","reporter","id",
"customfield_10030","issuetype","duedate","resolutiondate","customfield_10029",
"customfield_10056","customfield_10015","customfield_10088",
"customfield_10010","customfield_10097","timetracking","timespent",
"customfield_10093","creator","customfield_10091"
# -------------------- AUTH --------------------
def get_auth_header(email, token):
token_bytes = f"{email}:{token}".encode("utf-8")
base64_token = base64.b64encode(token_bytes).decode("utf-8")
return {
"Authorization": f"Basic {base64_token}",
"Accept": "application/json"
# -------------------- FETCH ALL ISSUE IDS --------------------
def fetch_all_issue_ids(jql):
start_at = 0
all_ids = []
print("Début de la récupération des IDs d'issues...")
while True:
payload = {"jql": jql, "startAt": start_at, "maxResults": MAX_RESULTS, "fields": ["id"]}
try:
response = requests.post(f"{JIRA_URL}/rest/api/3/search/jql",
headers=get_auth_header(EMAIL, API_TOKEN),
json=payload)
response.raise_for_status()
except requests.exceptions.RequestException as e:
print(f"Erreur HTTP à startAt={start_at}: {e}")
break
data = response.json()
issues = data.get("issues", [])
if not issues:
break
all_ids.extend([issue["id"] for issue in issues])
start_at += MAX_RESULTS
print(f"IDs récupérés : {len(all_ids)}")
time.sleep(0.2) # petit delay pour éviter les limites d'API
print(f"Total IDs récupérés : {len(all_ids)}")
return all_ids
# -------------------- FETCH DETAILED ISSUE --------------------
def fetch_issue_details(issue_id):
url = f"{JIRA_URL}/rest/api/3/issue/{issue_id}?fields=*all"
response = requests.get(url, headers=get_auth_header(EMAIL, API_TOKEN))
return response.json()
# -------------------- EXPORT EXCEL --------------------
def export_to_excel(issues_details, output_path):
wb = Workbook()
ws = wb.active
ws.title = "Jira Issues"
# En-têtes
ws.append(FIELDS_TO_KEEP)
# Fonction pour formater les valeurs
def format_value(value):
if isinstance(value, dict):
if not value:
return ""
return value.get("displayName") or value.get("name") or value.get("value") or str(value)
elif isinstance(value, list):
if not value:
return ""
return ", ".join([format_value(v) for v in value])
elif isinstance(value, str):
try:
return parser.parse(value).strftime("%Y-%m-%d")
except:
return value
else:
return str(value) if value is not None else ""
# Ajouter les lignes
for issue in issues_details:
fields = issue.get("fields", {})
row = []
for f in FIELDS_TO_KEEP:
if f == "key":
row.append(issue.get("key", ""))
elif f == "id":
row.append(issue.get("id", ""))
elif f == "timespent":
ts = fields.get("timespent") or (fields.get("timetracking", {}).get("timeSpentSeconds"))
row.append(ts if ts is not None else "")
elif f == "timetracking":
row.append(format_value(fields.get("timetracking", {})))
else:
row.append(format_value(fields.get(f, "")))
ws.append(row)
wb.save(output_path)
print(f"{len(issues_details)} issues exportées vers {output_path}")
# -------------------- MAIN --------------------
def main():
print("Début du script")
jql = f"filter={FILTER_ID}"
issue_ids = fetch_all_issue_ids(jql)
if not issue_ids:
print("Aucune issue récupérée, arrêt du script.")
return
issues_details = []
for idx, issue_id in enumerate(issue_ids, start=1):
print(f"Récupération de l'issue {idx}/{len(issue_ids)} : {issue_id}")
try:
details = fetch_issue_details(issue_id)
issues_details.append(details)
print(f"Erreur lors de la récupération de l'issue {issue_id}: {e}")
time.sleep(0.1) # petit delay pour limiter la charge
export_to_excel(issues_details, OUTPUT_PATH)
if __name__ == "__main__":
main()
Welcome to Atlassian Community.
You must use pagination, to get large number of issues.
Here is my code to get issues from Jira, through REST API
# Jira API endpoint for searching issues
jira_api_url = f"{jira_base_url}/rest/api/3/search/jql"
base64_credentials = base64.b64encode(
f"{jira_api_email}:{jira_api_token}".encode()
).decode()
headers = {
"Authorization": f"Basic {base64_credentials}",
"Content-Type": "application/json",
# Function to fetch issues based on JQL query using requests
def get_jira_issues(query, max_results=50):
issues = []
next_page_token = None
while True:
params = {
"jql": query,
"fields": ["comment", "customfield_12345"],
"maxResults": max_results,
if next_page_token:
params["nextPageToken"] = next_page_token
response = requests.get(jira_api_url, headers=headers, params=params)
if response.status_code == 200:
issues.extend(data.get("issues", []))
next_page_token = data.get("nextPageToken")
if not next_page_token:
break
else:
logger.error(f"Error fetching Jira issues: {response.text}")
raise Exception(f"Error fetching Jira issues: {response.text}")
return issues
Many thanks ! with your response and the next post also, my script working fine now !!! have a nice day
Hi @Martine Bombardelli ,
Welcome to Atlassian community. It's a common issue with the new v3 search api.
Please have a look to this thread for a solution: https://community.atlassian.com/forums/Jira-questions/Feature-change-during-CHANGE-2046/qaq-p/3103678
Many thanks ! It's working now (after two day of trying :-) :-) . Have a nice day
