problems after create projects
Francisco
March 14, 2020
Hello people, I have several problems with jira software. I create projects and then I can't access them, I create panels and I don't see them in projects. I am the advisor of Jira.
Dharma Ramos
March 16, 2020
When you say advisor, I take it you mean administrator.
To find the already created projects, look under the 'Administration' > 'Projects' section, find the project, click edit on the right and then add yourself to one of the roles that has permissions to view the project.
To view projects going forward, check the 'Administration' > 'System' section, within there, look for the 'Project roles' option under 'Security'. Check to see if you are a member of one of the groups in one of the roles under 'Manage Default Members' that gets added by default when a project gets created.
As for the panels, do you mean boards?
Francisco
March 16, 2020
Thanks, yes these answers was useful and solved my problems rigth.
Best regards.
