problems with cloning
srinivasp
January 10, 2013
my issue is that when people clone my template which is what I want them to do, I always get a bunch of emails wrt it being cloned.
I don’t want that to happen for the templates, what can be done about that?
LucasA
January 11, 2013
You can disable the notifications for your own actions when editing your profile. You can disable them temporarialy for clone the issue and enable it after that. Please check this documentation if you need any further assistance:
- https://confluence.atlassian.com/display/JIRA/Managing+your+User+Profile
Best regards,
Lucas Timm
srinivasp
January 11, 2013
Hi Lucas,
I believe you referred to disable the autowatch feature which is in the newest releases but we are using 4.4.5 release which is not present.
Thanks, Srinivas
