project info in Jira
shreedhar shreedhar October 17, 2012
How do I get project which is not accessed/used for more than some period of time?
Bhushan Nagaraj
October 18, 2012
Hi Shree,
You will have to go with the assumption that if no issues have been updated in a project for a long period of time (you can decide the period), then the project is no longer being used.
You can use JQL to find issues that have been not been updated for a long period of time.
For example, if you want to search for issues that were last updated before 12th December 2010, you can use the query
updated < "2010/12/12"
Documentation is available here
https://confluence.atlassian.com/display/JIRA/Advanced+Searching#AdvancedSearching-Updated
shreedhar shreedhar October 18, 2012
Hi Bhushan,
Thank you. You are right with that assumption. But, I think that is enough as of now to proceed further for my requirement. I don't know what percentage of my users go to old issues/tasks to refer back. That risk i need to take.
Thanks again..
