project key starting with numbers
fabio marcelo
Hi all,
How can i allow project keys in the format of 11TES ?
Thanks in Advance
Best Regards
Fabio
4 votes
Jobin Kuruvilla [Adaptavist]
December 11, 2011
As Nik says, you can't have project keys starting with numbers by default. But there is an option to change it. You can modify the
jira.projectkey.patter property unde Administration > General Configuration Advanced Settings to include the numbers etc.
([A-Z0-9][A-Z0-9]+) might be enough to get you started with numbers but you might want to check for atleast one letter in it!
NikE
December 11, 2011
Good catch Jobin - I was thinking we were talking about OnDemand where access to that page/making that change is a restricted function.
fabio marcelo
Hi Jobin,
Thanks a lot . It worked :)
Best Regards
Fabio
December 11, 2011
glad it helped.
Nik, I didn't know Advanced Settings is restricted on onDemand. Thanks for pointing out :)
Tom Towkach
Hi Fabio,
I hope you don't plan on integrating with FeCru. There are some JAC you should consider if you do:
FE-4144 FE-3968 FE-4155 FE-4148!
Just to name a few.
Best to avoid customzing those keys even though you can as Jobin mentions above.
NikE
December 11, 2011
Unfortunately you cannot set up project keys with numbers. The full rules and guidelines for project keys:
You must specify a unique project key, at least 2 characters long, containing only uppercase letters.
This is the unique project key. The project key:
* should be short and descriptive, as it prefixes each issue in the project;
* should not contain sensitive information, as it may be visible to users who do not have permission to view the project;
* cannot be changed once the project is created.
fabio marcelo
Hi Nik,
Thanks for the information.
Best Regards
Fabio
