We are looking to go for a top vendor or rated project management addon that is compatible with Jira Server 8.x version which will provide our top management a visibility of enterprise wide projects status and transparency on the following functionalities. Any suggestions on such addon would be greatly helpful to us. Thank You!
Hi @vcatl2020
Taking into account your requirements, BigPicture seems to be a good match! So let me add just a few words about the plugin. It’s a comprehensive tool that supports project management in every phase, helps to plan, manage and track the projects.
I will shortly introduce you main functionalities. However, if you share with me more specific requirements, my answer will be more precise.
Let’s start with the Gantt module.
Resources module
The Resources module provides all crucial information to manage resources both at project and portfolio levels but also can give an insight into resource utilization on a PI/Sprint level. You can display capacity, remaining capacity, and allocation both on the individual and Team level, which allows precise analyzing the consumption of currently utilized resources and forecasted availability. Data are color-coded what helps in the quick identification of both overallocation and under- allocation.
BigTemplate
With BigTemplate, you can export any data in one of the formats: pdf, xlsx, MPP, CSV. Once it’s done, it’s ready to distribute, print, send over e-mail, or instant messaging.
Data security
Security and project visibility may be set up on several levels. You can assign users to Global roles and then additionally adjust permissions on the project/box level.
Risks module
Risks heat-map can be used to show the level of risk resulting from the risk assessment by considering the category of probability or likelihood against the category of consequences or severity.
Other available modules:
Let me know if any questions come up! I will gladly answer them
Hi @Anna-BigPicture Thanks for the brief introduction of this addon and I started exploring its functionalities and indeed a bit complex and vast tool to configure and use, just the initial usage feeling. It looks like for the functionality that I'm looking for the company wide usage, I need to install BigPicture Enterprise along with BigTemplate addons.
Any other next best addon besides BigPicture in regards to the functionalities that I have included in my initial post?
I can assure you that once the plugin is configured, usage is very user-friendly.
Thank you for your feedback @vcatl2020! It's very precious information to us.
