project permission
Seth Frumkin September 8, 2016
When I change the permissions scheme for one project it affects all projects.  How can I avoid this?
Nic Brough -Adaptavist-
September 8, 2016
Create a new permission scheme and associate it with the project you want to handle separately to the others.
Seth Frumkin September 12, 2016
Thank you for the response.  I tried to figure this out in the Atlassian documentation but I traced it back to the (seemingly complicated) installation of something called Crucible.  Do I need to install this in order to create a permission scheme?
September 12, 2016
Eh?  No idea how you might have got there, that's quite a leap in the wrong direction!
All you need to do in your JIRA is separate out the schemes.  Let's say you have the default scheme and it's called permissions-A.  If you want to make project ABC work differently to project DEF, then you change the schemes for them.  Create a new permission scheme called permissions-B, set it up the way you need it and associate it with the DEF.
I'm having a difficult time finding the location of where I can change a permission scheme for an individual project.  If possible can you help me get there?
never mind got it!
