projects gadget with next open issue
Georg Schermann
June 23, 2014
Hi, i like the projects gadget very much since we have a lot of projects, but the summary shown for each project is not quite what we need. Is there a possibility to customize this summary so that we see the next open issue by due date? What we need is an overview of our projects where we see which issue is next for each project. Or is there a way to solve this with a filter?
Danilo Conrad
June 23, 2014
Hi Georg,
Unfortunately, it is not possible to customize the project summary in JIRA out-of-the-box.
A possible alternative would be to create a dashboard and use a filter to display the issues for the projects you want.
Danilo
Georg Schermann
June 24, 2014
Hi Danilo,
thanks for the quick answer! The problem with the issue filter is that i am not able to show only the next issue per project. So for every project i would like to see just one issue. I don't know if this is possible to achieve with a filter.
Cheers
