query Atlassian SDK C# to create an issue
Prajwal Shambhu
May 26, 2016
Hi All,
I have been trying to get this working but no luck yet.
I'm using JiraRestClient method to establish authentication request as shown in my snapshot.
When i'm trying to create a new Issue on one of my existing projects "VAC2016" but its throwing me an error
I really have a doubt in the way i have defined input parameters for "JIRARestClient" method.
currently we are on Atlassian JIRA cloud and i'm providing cloud URL on http protocol with my credentials.
is it the correct way of defining authentication using JIRARestClient method?
Error message says its "Unauthorized".
Can somebody shed some light on?
Prajwal Shambhu
An unhandled exception of type 'System.Security.Authentication.AuthenticationException' occurred in Atlassian.Jira.dll
Additional information: Response Content: <html>
<head>
    <title>Unauthorized (401)</title>
<!--[if IE]><![endif]-->
<script type="text/javascript">var contextPath = '';</script>
<script>
window.WRM=window.WRM||{};window.WRM._unparsedData=window.WRM._unparsedData||{};window.WRM._unparsedErrors=window.WRM._unparsedErrors||{};
WRM._unparsedData["com.atlassian.plugins.atlassian-plugins-webresource-plugin:context-path.context-path"]="\"\"";
WRM._unparsedData["jira.webresources:feature-flags.feature-flag-data"]="{\"enabled-feature-keys\":[\"jira.plugin.devstatus.smartcommits.dvcs.enabled\",\"nps.survey.inline.dialog\",\"rotp.admin.shortcuts\",\"jira.velocity.engine.warmup\",\"com.atlassian.jira.projects.issuenavigator.cachefix\",\"jira.plugin.devstatus.phasetwo\",\"jira.frother.reporter.field\",\"atlassian.rest.xsrf.legacy.enabled\",\"jira.administration.workflow.validation\",\"ondemand.language.beta\",\"dvcs.connector.smartcommits.disabled\",\"jira.issue.status.lozenge\",\"com.atlassian.jira.config.BIG_PIPE\",\"unified.usermanagement\",\"com.atlassian.jira.projects.issuenavigator\",\"jira.sidebar.components.managecomponents\",\"com.atlassian.jira.config.PDL\",\"jira.plugin.devstatus.phasetwo.enabled\",\"jira.project.config.old.components.screen.disabled\",\"com.atlassian.jira.projects.issue.summary.vignettes\",\"atlassian.aui.raphael.disabled\",\"com.atlassian.jira.config.CoreFeatures.PERMISSIONS_MANAGED_BY_UM\",\"app-switcher.new\",\"frother.assignee.field\",\"jira.onboarding.cyoa\",\"APDEX-517.warmhardcoded\",\"com.atlassian.jira.config.CoreFeatures.ON_DEMAND\",\"atlassian.plugin.aci.enabled\",\"com.atlassian.jira.config.ProjectConfig.MENU\",\"connect.no-applinks\",\"jira.event.mau.logging.disable\",\"rotp.project.create\",\"com.atlassian.plugins.issuenav.SEND_HEAD_EARLY\",\"jira.baseurl.cdn.enabled\",\"fusion.bitbucket.rebrand\",\"ka.SEPARATE_VIEWISSUE\",\"com.atlassian.jira.config.WEB_PANEL_METRICS\",\"sd.new.settings.sidebar.location.disabled\",\"com.atlassian.jira.config.CoreFeatures.LICENSE_ROLES_ENABLED\"],\"feature-flag-states\":{\"sd.reports.custom.drilldown\":true,\"sd.automation.workaround.jira.cached.index.issue\":true,\"jira.feature.flag.board\":true,\"jira.issue.search.jql.indexonly\":true,\"sd.new.settings.sidebar.location\":true,\"sd.automation.if.issue.link.type.phase2\":true,\"sd.automation.issue.linked.phase1\":true,\"sd.experimental.portal.search.algorithm.default.1\":false,\"sd.monitor.plugin.health.check\":false,\"sd.experimental.portal.search.algorithm.default.2\":false,\"sd.automation.issue.status.transitioned\":true,\"jira.shared.searchrequest.search.databaseprimary\":false,\"jira.shared.portalpage.search.indexprimary\":false,\"sd.kb.effectiveness.report\":true,\"sd.custom.email.notifications.batching\":false,\"jira.shared.portalpage.search.indexonly\":true,\"jira.feature.flag.board.polling\":true,\"jira.issue.search.jql.databaseprimary\":false,\"sd.stats.event.tracking\":true,\"jira.shared.searchrequest.search.indexprimary\":false,\"cloud.homepage\":true,\"jira.issue.search.jql.indexprimary\":false,\"jira.instrumentation.laas\":false,\"jira.feature.flag.board.labs\":true,\"jira.shared.portalpage.search.databaseprimary\":false,\"sd.reports.custom.export.dropdown\":true,\"sd.automation.then.linked.issue.comment.phase3\":true,\"sd.custom.email.notifications.single.sending\":true,\"sd.kb.issueview.panel.phase2\":true,\"jira.create.linked.issue\":true,\"sd.kb.issueview.panel\":true,\"sd.approval.requested.when.handler\":false,\"sd.stats.event.cleanup\":true,\"jira.shared.searchrequest.search.indexonly\":true,\"sd.approvals.light.weight\":false,\"sd.kb.usage.report\":true,\"sd.automation.then.webhook\":true,\"sd.request.type.automation.set\":true}}";
WRM._unparsedData["jira.webresources:default-comment-security-level.DefaultCommentSecurityLevelHelpLink"]="{\"extraClasses\":\"default-comment-level-help\",\"title\":\"Commenting on an Issue\",\"url\":\"https://confluence.atlassian.com/display/JIRACORECLOUD/Editing+and+collaborating+on+issues#Editingandcollaboratingonissues-restrictacomment\",\"isLocal\":false}";
WRM._unparsedData["com.atlassian.jira.project-templates-plugin:project-templates-plugin-resources.ptAnalyticsData"]="{\"instanceCreatedDate\":\"2014-12-13\"}";
WRM._unparsedData["com.atlassian.plugins.atlassian-connect-plugin:dialog-options.data"]="{\"dialogOptions\":{},\"inlineDialogOptions\":{},\"dialogModules\":{}}";
WRM._unparsedData["com.atlassian.plugins.atlassian-connect-plugin:jira-date-picker-widget.config"]="{\"dateFormat\":\"%e/%b/%y\",\"dateTimeFormat\":\"%e/%b/%y %I:%M %p\",\"timeFormat\":\"12\",\"firstDay\":1,\"useISO8601WeekNumbers\":false}";
WRM._unparsedData["jira.webresources:dateFormatProvider.dateFormat"]="{\"meridiem\":[\"AM\",\"PM\"],\"eras\":[\"BC\",\"AD\"],\"months\":[\"January\",\"February\",\"March\",\"April\",\"May\",\"June\",\"July\",\"August\",\"September\",\"October\",\"November\",\"December\"],\"monthsShort\":[\"Jan\",\"Feb\",\"Mar\",\"Apr\",\"May\",\"Jun\",\"Jul\",\"Aug\",\"Sep\",\"Oct\",\"Nov\",\"Dec\"],\"weekdaysShort\":[\"Sun\",\"Mon\",\"Tue\",\"Wed\",\"Thu\",\"Fri\",\"Sat\"],\"weekdays\":[\"Sunday\",\"Monday\",\"Tuesday\",\"Wednesday\",\"Thursday\",\"Friday\",\"Saturday\"]}";
WRM._unparsedData["com.atlassian.pocketknife.featureflags-plugin:pocketknife-feature-flags.feature-flag-data"]="{\"enabled-feature-keys\":[\"jira.plugin.devstatus.smartcommits.dvcs.enabled\",\"nps.survey.inline.dialog\",\"rotp.admin.shortcuts\",\"jira.velocity.engine.warmup\",\"com.atlassian.jira.projects.issuenavigator.cachefix\",\"jira.plugin.devstatus.phasetwo\",\"jira.frother.reporter.field\",\"atlassian.rest.xsrf.legacy.enabled\",\"jira.administration.workflow.validation\",\"ondemand.language.beta\",\"dvcs.connector.smartcommits.disabled\",\"jira.issue.status.lozenge\",\"com.atlassian.jira.config.BIG_PIPE\",\"unified.usermanagement\",\"com.atlassian.jira.projects.issuenavigator\",\"jira.sidebar.components.managecomponents\",\"com.atlassian.jira.config.PDL\",\"jira.plugin.devstatus.phasetwo.enabled\",\"jira.project.config.old.components.screen.disabled\",\"com.atlassian.jira.projects.issue.summary.vignettes\",\"atlassian.aui.raphael.disabled\",\"com.atlassian.jira.config.CoreFeatures.PERMISSIONS_MANAGED_BY_UM\",\"app-switcher.new\",\"frother.assignee.field\",\"jira.onboarding.cyoa\",\"APDEX-517.warmhardcoded\",\"com.atlassian.jira.config.CoreFeatures.ON_DEMAND\",\"atlassian.plugin.aci.enabled\",\"com.atlassian.jira.config.ProjectConfig.MENU\",\"connect.no-applinks\",\"jira.event.mau.logging.disable\",\"rotp.project.create\",\"com.atlassian.plugins.issuenav.SEND_HEAD_EARLY\",\"jira.baseurl.cdn.enabled\",\"fusion.bitbucket.rebrand\",\"ka.SEPARATE_VIEWISSUE\",\"com.atlassian.jira.config.WEB_PANEL_METRICS\",\"sd.new.settings.sidebar.location.disabled\",\"com.atlassian.jira.config.CoreFeatures.LICENSE_ROLES_ENABLED\"],\"feature-flag-states\":{\"sd.reports.custom.drilldown\":true,\"sd.automation.workaround.jira.cached.index.issue\":true,\"jira.feature.flag.board\":true,\"jira.issue.search.jql.indexonly\":true,\"sd.new.settings.sidebar.location\":true,\"sd.automation.if.issue.link.type.phase2\":true,\"sd.automation.issue.linked.phase1\":true,\"sd.experimental.portal.search.algorithm.default.1\":false,\"sd.monitor.plugin.health.check\":false,\"sd.experimental.portal.search.algorithm.default.2\":false,\"sd.automation.issue.status.transitioned\":true,\"jira.shared.searchrequest.search.databaseprimary\":false,\"jira.shared.portalpage.search.indexprimary\":false,\"sd.kb.effectiveness.report\":true,\"sd.custom.email.notifications.batching\":false,\"jira.shared.portalpage.search.indexonly\":true,\"jira.feature.flag.board.polling\":true,\"jira.issue.search.jql.databaseprimary\":false,\"sd.stats.event.tracking\":true,\"jira.shared.searchrequest.search.indexprimary\":false,\"cloud.homepage\":true,\"jira.issue.search.jql.indexprimary\":false,\"jira.unified.attachments.m2\":true,\"jira.instrumentation.laas\":false,\"jira.feature.flag.board.labs\":true,\"jira.shared.portalpage.search.databaseprimary\":false,\"sd.reports.custom.export.dropdown\":true,\"sd.automation.then.linked.issue.comment.phase3\":true,\"sd.custom.email.notifications.single.sending\":true,\"sd.kb.issueview.panel.phase2\":true,\"jira.create.linked.issue\":true,\"jira.unified.attachments\":true,\"sd.kb.issueview.panel\":true,\"sd.approval.requested.when.handler\":false,\"sd.stats.event.cleanup\":true,\"jira.attachment.merge\":true,\"jira.shared.searchrequest.search.indexonly\":true,\"sd.approvals.light.weight\":false,\"sd.kb.usage.report\":true,\"sd.automation.then.webhook\":true,\"sd.request.type.automation.set\":true}}";
WRM._unparsedData["com.atlassian.jira.plugins.jira-dnd-attachment-plugin:jira-html5-attach-images-resources.resource-uris"]="{\"deployJava.html\":\"/s/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/4.2.15/_/download/resources/com.atlassian.jira.plugins.jira-dnd-attachment-plugin:jira-html5-attach-images-resources/deployJava.html\",\"clipboard.jar\":\"/s/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/4.2.15/_/download/resources/com.atlassian.jira.plugins.jira-dnd-attachment-plugin:jira-html5-attach-images-resources/clipboard.jar\",\"clipboard-legacy.jar\":\"/s/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/4.2.15/_/download/resources/com.atlassian.jira.plugins.jira-dnd-attachment-plugin:jira-html5-attach-images-resources/clipboard-legacy.jar\"}";
WRM._unparsedData["com.atlassian.applinks.applinks-plugin:applinks-common.applinks-context"]="{\"hostApplication\":{\"id\":\"77c28f3a-117d-35b7-9eb7-720522287e52\",\"type\":\"jira\"}}";
WRM._unparsedData["com.atlassian.applinks.applinks-plugin:applinks-common.applinks-features"]="{\"BITBUCKET_REBRAND\":false,\"V3_UI_OPT_IN\":false,\"V3_UI\":false}";
WRM._unparsedData["com.atlassian.applinks.applinks-plugin:applinks-common.applinks-discovered-features"]="[]";
WRM._unparsedData["com.atlassian.applinks.applinks-plugin:applinks-common.applinks-help-paths"]="{\"entries\":{\"applinks.docs.root\":\"https://confluence.atlassian.com/display/APPLINKS-050/\",\"applinks.docs.diagnostics.troubleshoot.sslunmatched\":\"SSL+and+application+link+troubleshooting+guide\",\"applinks.docs.diagnostics.troubleshoot.oauthtimestamprefused\":\"OAuth+troubleshooting+guide\",\"applinks.docs.delete.entity.link\":\"Create+links+between+projects\",\"applinks.docs.adding.application.link\":\"Link+Atlassian+applications+to+work+together\",\"applinks.docs.administration.guide\":\"Application+Links+Documentation\",\"applinks.docs.oauth.security\":\"OAuth+security+for+application+links\",\"applinks.docs.troubleshoot.application.links\":\"Troubleshoot+application+links\",\"applinks.docs.diagnostics.troubleshoot.unknownerror\":\"Network+and+connectivity+troubleshooting+guide\",\"applinks.docs.configuring.auth.trusted.apps\":\"Configuring+Trusted+Applications+authentication+for+an+application+link\",\"applinks.docs.diagnostics.troubleshoot.authlevelunsupported\":\"OAuth+troubleshooting+guide\",\"applinks.docs.diagnostics.troubleshoot.ssluntrusted\":\"SSL+and+application+link+troubleshooting+guide\",\"applinks.docs.diagnostics.troubleshoot.unknownhost\":\"Network+and+connectivity+troubleshooting+guide\",\"applinks.docs.delete.application.link\":\"Link+Atlassian+applications+to+work+together\",\"applinks.docs.link.applications\":\"Link+Atlassian+applications+to+work+together\",\"applinks.docs.diagnostics.troubleshoot.oauthproblem\":\"OAuth+troubleshooting+guide\",\"applinks.docs.relocate.application.link\":\"Link+Atlassian+applications+to+work+together\",\"applinks.docs.administering.entity.links\":\"Create+links+between+projects\",\"applinks.docs.upgrade.application.link\":\"OAuth+security+for+application+links\",\"applinks.docs.diagnostics.troubleshoot.connectionrefused\":\"Network+and+connectivity+troubleshooting+guide\",\"applinks.docs.configuring.auth.oauth\":\"OAuth+security+for+application+links\",\"applinks.docs.insufficient.remote.permission\":\"OAuth+security+for+application+links\",\"applinks.docs.configuring.application.link.auth\":\"OAuth+security+for+application+links\",\"applinks.docs.diagnostics\":\"Application+links+diagnostics\",\"applinks.docs.configured.authentication.types\":\"OAuth+security+for+application+links\",\"applinks.docs.adding.entity.link\":\"Create+links+between+projects\",\"applinks.docs.diagnostics.troubleshoot.unexpectedresponse\":\"Network+and+connectivity+troubleshooting+guide\",\"applinks.docs.configuring.auth.basic\":\"Configuring+Basic+HTTP+Authentication+for+an+Application+Link\",\"applinks.docs.diagnostics.troubleshoot.authlevelmismatch\":\"OAuth+troubleshooting+guide\"}}";
WRM._unparsedData["jira.webresources:avatar-picker.data"]="{\"isEnabled\":false,\"url\":\"/plugins/servlet/redirectToProfile?target=edit-avatar\"}";
WRM._unparsedData["com.atlassian.jira.jira-header-plugin:dismissedFlags.flags"]="{\"dismissed\":[]}";
WRM._unparsedData["com.atlassian.plugins.helptips.jira-help-tips:common.JiraHelpTipData"]="{\"anonymous\":true}";
WRM._unparsedData["com.atlassian.jira.jira-header-plugin:newsletter-signup-tip.newsletterSignup"]="{\"signupDescription\":\"Stay up-to-date with the latest JIRA tips, tricks, and exclusive inside jokes. All this and more in JIRA Insiders, delivered every month from our inbox to yours.\",\"formUrl\":\"https://www.atlassian.com/apis/exact-target/{0}/subscribe?mailingListId=1239131\",\"signupTitle\":\"JIRA Insiders\",\"signupId\":\"newsletter-signup-tip\",\"showNewsletterTip\":false}";
WRM._unparsedData["com.atlassian.jira.ext.calendar:tipDataProvider.tip"]="{\"suppressTip\":false}";
WRM._unparsedData["jira.webresources:user-message-flags.adminLockout"]="{}";
if(window.WRM._dataArrived)window.WRM._dataArrived();</script>
<link type="text/css" rel="stylesheet" href="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/f14211ef516de9d893247542a0290ef2-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/2717a8168e620d6979a7b712bc04a5a9/_/download/contextbatch/css/_super/batch.css?atlassian.aui.raphael.disabled=true&amp;relative-url=true" data-wrm-key="_super" data-wrm-batch-type="context" media="all">
<!--[if lte IE 9]>
<link type="text/css" rel="stylesheet" href="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/f14211ef516de9d893247542a0290ef2-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/2717a8168e620d6979a7b712bc04a5a9/_/download/contextbatch/css/_super/batch.css?atlassian.aui.raphael.disabled=true&amp;conditionalComment=lte+IE+9&amp;relative-url=true" data-wrm-key="_super" data-wrm-batch-type="context" media="all">
<![endif]-->
<link type="text/css" rel="stylesheet" href="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/c53ba5328fc67fe48f4fd6ecf51760cb-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/39f5457f149cb776590a996424e7e0c4/_/download/contextbatch/css/atl.general,jira.global,jira.general,-_super/batch.css?agile_global_admin_condition=true&amp;atlassian.aui.raphael.disabled=true&amp;hasConnectAddons=true&amp;jag=true&amp;relative-url=true&amp;tempo_is_jira_version_equal_or_greater_than_7.0.0=true&amp;tempo_is_tempo_core_licensed=true&amp;tempo_is_tempo_timesheets_license_valid=false" data-wrm-key="atl.general,jira.global,jira.general,-_super" data-wrm-batch-type="context" media="all">
<script type="text/javascript" src="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/5574694eb53183bd16a4da808d59e11f-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/2717a8168e620d6979a7b712bc04a5a9/_/download/contextbatch/js/_super/batch.js?atlassian.aui.raphael.disabled=true&amp;locale=en-US" data-wrm-key="_super" data-wrm-batch-type="context" data-initially-rendered></script>
<script type="text/javascript" src="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/4a3cd4abc504b801c2c3eeb3bd83b27f-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/39f5457f149cb776590a996424e7e0c4/_/download/contextbatch/js/atl.general,jira.global,jira.general,-_super/batch.js?agile_global_admin_condition=true&amp;atlassian.aui.raphael.disabled=true&amp;hasConnectAddons=true&amp;jag=true&amp;locale=en-US&amp;tempo_is_jira_version_equal_or_greater_than_7.0.0=true&amp;tempo_is_tempo_core_licensed=true&amp;tempo_is_tempo_timesheets_license_valid=false" data-wrm-key="atl.general,jira.global,jira.general,-_super" data-wrm-batch-type="context" data-initially-rendered></script>
<script type="text/javascript" src="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/db3d688ec63f4ace1d8c476e4776ea23-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/9296915968fd19e3630cf5546b9a3e64/_/download/contextbatch/js/atl.global,-_super/batch.js?atlassian.aui.raphael.disabled=true&amp;locale=en-US" data-wrm-key="atl.global,-_super" data-wrm-batch-type="context" data-initially-rendered></script>
<link type="text/css" rel="stylesheet" href="//d2p4ir3ro0j0cb.cloudfront.net/inobitsme.atlassian.net/s/78f21f0833c1ebc1ae3162d7f2c40740-CDN/-srycvj/72002/c2b606d976f1967f744e8fecdf4e13eb/9bb8596866a50ca294e985c53a2ba633/_/download/contextbatch/css/jira.global.look-and-feel,-_super/batch.css?atlassian.aui.raphael.disabled=true&amp;relative-url=true" data-wrm-key="jira.global.look-and-feel,-_super" data-wrm-batch-type="context" media="all">
<script type="text/javascript" src="/rest/api/1.0/shortcuts/72002/29dd2166996497122518e73339b82b53/shortcuts.js"></script>
    <meta name="application-name" content="JIRA" data-name="jira" data-version="1000.5.2">
</head>
<body id="jira" class="aui-layout aui-style-default page-type-message"  data-version="1000.5.2" >
    <div class="aui-page-panel"><div class="aui-page-panel-inner">
            <section class="aui-page-panel-content">
                    <header class="aui-page-header"><div class="aui-page-header-inner">
                            <div class="aui-page-header-main">
                                    <h1>Unauthorized (401)</h1>
                                </div><!-- .aui-page-header-main -->
                        </div><!-- .aui-page-header-inner --></header><!-- .aui-page-header -->
                    <div class="aui-message aui-message-warning warning">
                            <p>Encountered a <code>&quot;401 - Unauthorized&quot;</code> error while loading this page.</p>
                            <p><a href="/secure/MyJiraHome.jspa">Go to JIRA home</a></p>
                        </div>
                </section><!-- .aui-page-panel-content -->
        </div><!-- .aui-page-panel-inner --></div><!-- .aui-page-panel -->
</body>
</html>
Alex Medved _ConfiForms_
What's the package you use (could not find anything like Atlassian,Jira)?
 Unathorized states that you are not authorized to do the operation, but can you make a query to list some issues? Does that work?
