I have a Next-gen project. On the Roadmap page there is a menu item on the left to "Add Item". Apparently this allows you to link a repository or create a shortcut to a web page. When I click "Add Item" a dialog pops up and I click "Add" next to "Shortcut - Add a link to a frequently used resource, like a web page". I am expecting an interface to appear where I can add my URL but nothing happens. Has anyone had this same issue?
Workaround Only - not a fix
Found why the potential discrepancy.
If i am viewing the roadmap -- and i click on Add Item - the first screen appears - i click on add shortcut and nothing happens (i do not see the above screen)
HOWEVER
if i am viewing the board view and i click on Add item -- i get to the above screen and can add item.
Appears to be a Bug - but the above workaround should hopefully help @Hal Leiner
Hello Hal,
Adding a shortcut is working as expected for me. It might be an issues related to your browser, can you try another browser and see if that resolves it.
My first attempt was in Internet Explorer. I retried in Google. No luck with either browser.
Exactly the same issue for me -- tried in Chrome and Safari - not working - the screen pic above is not presented when one clicks on the add short option
HOWEVER
