×Hi.
I tried to create an Automation and didn't found the Automation Link. Is this only available on Cloud? or should it also be on Server (On-Premise).
Unfortunately a different employee set up the system, who didn't work here any longer. So i don't know if this is just a Setting that I (or he) just missed or misconfigured.
The picture shows you all the options I have.
Thanks for help.
Hi @Peter ,
The Automation you currently can find a lot of information about is indeed something that is available on Cloud by default. (it is the acquisition from CodeBarrel).
On server however you do have the marketplace option still which gives you the same.
The app is called Automation for Jira (by Codebarrel or Atlassian now). They also have a Lite version which is free if I'm not mistaken.
What could be the reason why it is missing in some projects but visible in others?
