"Comment body cannot be empty" error after upgrading from 8.22 to 9.0
Lorenzoc July 21, 2022
We cannot add any more comment to any issue in our hosted Jira installation, after upgrading to version 9.0.
Zul NS [Atlassian]
August 15, 2022
Hi there,
We've received a few of these types of issues in Support, specifically on the "Comment body cannot be empty" warning/error. Investigate and identified to be related to an older version of "Jira Threaded Comments" app. Could you have a look and see if disabling the said app helps?
We have KB article created on this found in https://confluence.atlassian.com/display/JIRAKB/Periodically+unable+to+add+comments+to+tickets
We're also looking into reaching out to the vendor to share the findings.
Lorenzoc August 22, 2022
I can confirm that the problem is related to the "Jira Threaded Comments" app.
Disabling the app, I can add a comment to any issue.
Re-enabling it, the error comes out again.
I'm waiting for the fix from the vendor.
Like Zul NS [Atlassian] likes this
Jennifer Kelley August 12, 2022
Having the same issue after upgrading to Jira Server 9.1.0
Mateus Machado
July 25, 2022
We're having the same problem in Jira Server 9.1.0. It does happen with both new or existing issues. However, we noticed that the first comment attempt works fine, but it doesn't work when user tries to add a second comment.
We also found a workaround which is to click the "Edit" button in the upper side of the issue, and then use the Comment section at the bottom of the form to add new comments.
Hoping to see a fix soon...
Lorenzoc July 25, 2022
Hi Mateus,
Yes, it happens with issues that already have at least one comment.
Thanks for the workaround, it works.
Adding a comment also works in the boards section: if you select an issue in a board and try to add a comment in the issue section at the right of the screen, you can do it.
If you open the issue 'full screen', you can't.
It seems that only the 'add comment' button in the main issue form is affected, we really hope it can be fixed soon
Like Mateus Machado likes this
Just found that this error happens only if we add comments to existing issues.
If we create a new issue, we can add comments to it.
SERVER
VERSION
9.0
