I have a fresh Jira Software project created using the Scrum template. I'd like to use Components, which I've seen teammates use in other workspaces, and which seem to be documented; however, I don't see a "Components" option in my project settings as described. We're currently using the Free plan, but I can't find documentation indicating that this feature is available exclusively on non-free tiers.
Am I missing something or misunderstanding? Much appreciated.
Hello @Katie Wolfe
Welcome to the Atlassian community!
Are you working with a Company Managed project or a Team Managed project? It will say at the bottom of the navigation pane on the left.
Components is a feature available only for Company Managed projects at this time. If you are working with a Team Managed project, Components is not yet available. The change request for that is here:
It's found in the left nav menu, but you can toggle it on/off by going into the project settings and looking at the Features menu.
Here's some screenshots from my free instance.
Click on the slide bar there you have option of components
