"Tempo" missing from top menu system
Truong Tan Dat
May 4, 2017
I no longer have the "Tempo" menu at the to top of my JIRA instance. And Im using on a server instance.
I cannot access Tempo Time Tracking either.
Nic Brough -Adaptavist-
May 5, 2017
The most likely explanation is that the Tempo add-on is disabled for some reason.
Can you check in the list of add-ons what its status is?  Look specifically for an error, the "disabled" flag and its licence status.
Sam Hall
May 4, 2017
If nobody can help here, you could try contacting the add-on vendor:
https://support.tempo.io/hc/en-us/requests/new
http://www.tempo.io/support
https://marketplace.atlassian.com/plugins/is.origo.jira.tempo-plugin/server/support
In the meantime, I'll add tags to your question to give if a better chance of being picked up.
