"Unknown system variable 'storage_engine'" JIRA 7.0 and MySQL 5.7.9
Semen Pleshivtsev
November 3, 2015
Hi!
I'm trying to install JIRA 7.0 on MySQL  5.7.9 and connector "mysql-connector-java-5.1.37-bin.jar".
When I'm trying to connect to MySQL DB, error message appears:
This variable is NOT present in my.ini. Insead, I'm using default-storage-engine = InnoDB.
Well, system variable storage_engine is deprecated "as of MySQL 5.5.3".
Should I use version of MySQL below 5.5.3 ?
Best regards, Semyon.
13 votes
yurii-bitbucket
December 26, 2015
i got it working
in short see my fork : https://github.com/yurii-github/mysql-connector-j
changing JIRA was too hard for me, too many places with hardcoded storage_engine parameter, so i did a change into mysql connector itself - i'm replacing deprecated variable in connection constructor. like this
https://github.com/yurii-github/mysql-connector-j/commit/47199bf3ef4a9c3db6eb3a1858fc53c980d8a439
built snapshot is in repo too: https://github.com/yurii-github/mysql-connector-j/blob/release/5.1/mysql-connector-java-5.1.38-SNAPSHOT-bin.jar
or you can build it yourself etc.
just note, it was built without jdk1.6. Also no warranties etc, you know smile
hope it helps and doesn't crash for you, it works for me though.
regards,
Yurii
MattS
January 7, 2016
That's a cool piece of work but where else was storage_engine hard coded? https://answers.atlassian.com/questions/32023132/answers/32522729 looked like you could just tweak dbconfig.xml no?
yurii-bitbucket
January 8, 2016
unfortunately i didnt save search progress. as i remember, just changing dbconfig didn't help me. i found hardcoded "storage_engine" about 4 times. some in text files INF or something, some in plugins in jar files. but even after i repackaged jar files it was still failing with this error. i think some hardcoded link(s) still exist in obfuscated compiled code, haven't look too much into this as connector license allows me to modify its code and in one place. anyway, if changing config file works for you - great. i wonder why it didnt work for me then regards
Emil Georgiev
June 20, 2016
Thank you!!!  After 2 days of searching and trying to get around this, I finally was able to get a successful connection with your jar!
dvittor
July 9, 2016
Legend Yurii K. Thank you. Your mysql-snapshot.jar worked.
tommy yang
September 7, 2016
Modify mysql.properties and dbconfig.xml doesn't take effect. Use Yurii's script solve the problem. Thank you! Yurii K.
Ubuntu 16.04 Mysql 5.7.13
Deleted user November 26, 2016
Thank you! My JIRA broke after Ubuntu 14->16 upgrade. Using your .jar variant fixed the problem
Metin _savignano software solutions_
Warning: This solution worked for me for about two months, but then I had NPE problems in a JIRA function which I had not used before. It took me a while to find out that this modified driver jar caused the problems. After that I re-installed the original driver and used Vin's solution listed below instead. All works fine now.
DoskulovDS
September 29, 2018
Thank you so much!!!!
5 votes
Vin
November 21, 2015
Here are the steps to get around:
  1. If you are doing this the first time, copy the sample dbconfig.xml from https://confluence.atlassian.com/adminjiraserver070/connecting-jira-applications-to-mysql-749382640.html, else edit the existing dbconfig.xml as an administrator. It is in the JIRA HOME folder.
  2. Search for <url> tag in the file.
  3. Remove the text: "sessionVariables=storage_engine=InnoDB" (sans double-quotes).
  4. Ensure that the server and database name match the ones specified during installation.
  5. Restart JIRA.
Frank Adcock
May 12, 2016
sudo vi /opt/atlassian/jira/atlassian-jira/WEB-INF/classes/database-defaults/mysql.properties
Remove the text as stated above including the preceding & character.
vellotis
June 5, 2016
Thank you @Vin.
To the others: It is not needed to modify connector. Just modify the dbconfig.xml.
Daniel Duerr
June 15, 2016
@Frank Adcock nailed the solution for a new JIRA install, since it won't look at the dbconfig.xml file when the setup wizard is wanting to be run.
Vectalis June 21, 2016
warning Actually the is that dbconfig.xml does not exist when running the installation for the first time
either
  • copy and tune the sample as suggested above or
  • using the config tool (in JiraInstallation/bin) and generate one... then tune it (to remove the "storage_engine..." part
David Rhoderick
August 19, 2016
I upgraded to Ubuntu 16.04 and that upgraded my MySQL, which caused the error.  I tried what Vin wrote and also what @Frank Adcock wrote and I'm stuck on the setup page.  Is my only option to edit the MySQL connector if migrating from something before?
Alexander Oberhauser
August 26, 2016
Hey guys! Thank you very much for your tips, worked for me like charm. Had to update Ubuntu to 16.04 from 14.04 and this did the trick! I did the following:
  1. I removed the "InnoDB" inside dbconfig.xml
  2. Next I also removed it via ${JIRA_APPLICATION_DIR}/atlassian-jira/WEB-INF/classes/database-defaults/mysql.properties. Please refer to http://dba.stackexchange.com/a/138423 for further details.
Now everything seems to be working fine!
Like Attila Odry likes this
aamirmunir
October 18, 2016
Hi guys I did the same but after doing this it says unable to test connection. Any suggestion?
aamirmunir
October 19, 2016
Hi All,
Please I am kind of stuck here and really need some quick help.
I am using MySQL 5.7.15
and JIRA 7.2.3
I did remove "sessionVariables=storage_engine=InnoDB" from dbcongif.xml (that I created using the sample), I also try to remove it from mysql.properties file under /atlassian-jira/WEB-INF/classes/database-defaults/
but no luck when I click Test connection it says : Unable to test the connection.
Any quick help really appritiated.
SABVARX
Thanks a lot for that great hint, Vin! I just had to remove the text while upgrading to mysql 5.7 for my JIRA 7.3 installation.
In JIRA 7.3 (which supports mySQL 5.7), storage_engine has become default_storage_engine. I haven't tried changing the variable in JIRA 6.4, but I suppose this would be the correct way to solve this problem.
Robert Ordóñez
January 16, 2018
Still a problem in 2018, with the upgrade from Ubuntu 14 LTS to 16 LTS. :(
To save someone else some time: dbconfig.xml is at /var/atlassian/application-data/jira/dbconfig.xml
Attila Odry
December 3, 2018
Thanks for all, especially for @DudaevAR Oberhauser  your clean solution / links worked for me too.
I upgraded my server from Ubuntu 14.04.5 LTS and JIRA 6.4.11 to Ubuntu 18.4 LTS, same Jira version (will update that later), the problem popped up at 16.x LTS, but I just skipped, went to latest 18.4 and fixed as described in this link:
You saved my day, well night or morning :)
Thanks again guys!
Matt White November 4, 2015
Yah, same issue here. rolled back to mysql 5.6.27 and it is happy now.
Maxim Lebedev
January 2, 2017
Meet with a same problem. And it has been fixed by rollback to to mysql 5.6.27
Samrat Basra
June 29, 2017
yes. it will work with mysql 5.6.
Andrew Claridge
November 5, 2015
Fabian Wallentowitz
November 3, 2015
same here....
the mysql connector url should be defineable as in the confluence setup...
Gyana Ranjan January 25, 2017
Thanks a lot.. It works!
Paul Stewart December 9, 2016
Just got burned by this myself.. 5.7 has been out for quite some time and was surprised to see this issue come up.
MattS
November 4, 2015
There's a feature request at jac for this.
MattS
January 7, 2016
