"Week is closed" problem when logging work in issues
Manuel Dias
June 2, 2015
My colleagues cannot log work in JIRA issues, since they get the "Week is closed" error.
Is it possible to re-open a specific period? I checked in Tempo addon, section "Period management" but the period is already open...
Please help!
mdias
William Crossland August 8, 2018
I was able to solve this issue by temporarily disabling the Scheduler (Jira Administration->Add Ons->Tempo->Scheduler)
- Uncheck "Activate This Scheduler"
Marcela Furyová August 30, 2018
Thanks for solution. It works.
Manuel Dias
June 9, 2015
Hi Jaime,
No, I tried that also that but it does not work: the error is the same, even if the period is changed to open.
If you know other way to solve this, please send.
Manuel Dias
Jaime S
June 9, 2015
That was the only idea I had. Maybe somebody else will give you a better answer.
green_at_pixolut
December 12, 2016
I am having the same issue. Period Management solution mentioned below doesn't work
Francesco Salvi June 27, 2018
Hello, I'm coping with the same issue. Even if the period is "open for all", when logging time on that period it says "period is closed" . pls help!  tks
Angelica Olmsted
August 3, 2018
Did anyone find a solution to this issue?  I confirmed Period Management is open and the user has edit Approve Timesheet permissions but am still unable to log?
Sergey Karaev _Aplana_ November 14, 2019
Hi, are you resolved this problem ?
Admin July 4, 2018
mee to all period open but we get this error
Jaime S
June 9, 2015
Hi, Manuel.
By checking this documentation, it seems that is's possible to re-open. This configuration seems to be in the Period Management page.
Jaime Kirch da Silveira
Atlassian Cloud Support
