I try to create an issue when create the first issue in a workflow (default "Create" transition) but this does not work.
esta es la transicióninicialen el flujo de trabajo.
Pantalla: Ninguna - transición incial no tiene una vista.
Lo siguiente se procesará luego de realizada la transición
I think I got it. This sould work without any problem so my previous comment was wrong. But as I see in the doc you have to move up the 'Creates the issue originally' postfunction. The doc is for the subtasks but is the same:
https://bobswift.atlassian.net/wiki/display/CSOT/How+to+create+subtasks+on+initial+issue+create
And just in case someday you change your postfunction, make sure that you don't create in the postfunction the same issue type that you are creating manually becuase this will create a loop. For example, if you create a task that has a postfunction that creates a task it will result in a loop.
Good answer and the warning is especially important ;).
Thanks Bob :)
But I want the same issue type in the post function that the one I create manually. Is this not possible? Effectivelly now I have a loop.
Well it is possible, but, you have to figure out another condition that will prevent the looping as described in https://bobswift.atlassian.net/wiki/display/CSOT/How+to+create+subtasks+on+initial+issue+create
Hi, If I remember correctly there was a problem when creating a issue in the create transition, but I can't find the issue created for this. Just to make sure, it's working fine in the other transitions?
