"create issue" with post function oncreateTransition does not work in create transition
Irene Espadas October 16, 2014
I try to create an issue when create the first issue in a workflow (default "Create" transition) but this does not work.
Transición: Create
  1. Create
esta es la transicióninicialen el flujo de trabajo.
Pantalla: Ninguna - transición incial no tiene una vista.
Añadir función posterior
Lo siguiente se procesará luego de realizada la transición
  1. Create issue
    Conditions:
    • Condition value: %IssueType%, Regex pattern: Task
    Summary:
    Description:
    Project: Original project
    Issue type: Bug (1)
    Priority: Parent's priority
    Reporter: Current user
    Assignee: Parent issue's assignee
    Affected versions: None
    Fixed versions: None
    Components: Parent issue's components
    Copy parent issue custom fields: Descripción
    Copy original issue custom fields: Motivo petición
  2. Crea una incidencia de origen.
  3. Reindexar una incidencia para mantener los índices sincronizados con la base de datos.
  4. Disparar un evento Incidencia creada que puede ser procesado por escuchadores.
Ramiro P
October 16, 2014
I think I got it. This sould work without any problem so my previous comment was wrong. But as I see in the doc you have to move up the 'Creates the issue originally' postfunction. The doc is for the subtasks but is the same:
https://bobswift.atlassian.net/wiki/display/CSOT/How+to+create+subtasks+on+initial+issue+create
Ramiro P
October 16, 2014
And just in case someday you change your postfunction, make sure that you don't create in the postfunction the same issue type that you are creating manually becuase this will create a loop. For example, if you create a task that has a postfunction that creates a task it will result in a loop.
Bob Swift
October 16, 2014
Good answer and the warning is especially important ;).
Ramiro P
October 16, 2014
Thanks Bob :)
Irene Espadas October 20, 2014
But I want the same issue type in the post function that the one I create manually. Is this not possible? Effectivelly now I have a loop.
Bob Swift
October 20, 2014
Well it is possible, but, you have to figure out another condition that will prevent the looping as described in https://bobswift.atlassian.net/wiki/display/CSOT/How+to+create+subtasks+on+initial+issue+create
Ramiro P
October 16, 2014
Hi, If I remember correctly there was a problem when creating a issue in the create transition, but I can't find the issue created for this. Just to make sure, it's working fine in the other transitions?
Yes, it works fine in the other transitions
