I am using the following 'Custome Script Post Function' on 'Create' transition and is the first post-function and does not seem to work. It is checking for the issue type of a ticket, based on the issuetype a Custom field(select list) needs to be set up to a certain value 'XYZ':
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
def customerPriority = issue.getCustomFieldValue(customFieldManager.getCustomFieldObject("customfield_12345"));
if(issue.issueTypeObject.name == "ABC")
issue.setCustomFieldValue(customerPriority,'XYZ')
issue.store();
Any suggestions as to what might be wrong with the above code?
Rupa
So, for cases where updating the issue attributes isn't working, it's a good idea to try using the IssueService to perform the update. Per the note in the ScriptRunner docs, you normally need to update issue attributes before it gets stored in the database.
You can only use this method to update issue attributes if your script post-function comes before the standard function Update change history for an issue and store the issue in the database. If you need your function to run after that, you have to use a more complex method.
This can be a little trickier with the create transition, as its post-functions are different from other workflow transitions.
To use the IssueService in this case, try something like this:
import com.atlassian.jira.bc.issue.IssueService import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.event.type.EventDispatchOption import com.atlassian.jira.issue.IssueInputParametersImpl if (issue.issueTypeObject.name == "ABC") { def customFieldManager = ComponentAccessor.getCustomFieldManager() def customField = customFieldManager.getCustomFieldObject("customfield_12345") def issueService = ComponentAccessor.getIssueService() def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser() def issueInputParams = new IssueInputParametersImpl().addCustomFieldValue(customField.id, "XYZ") IssueService.UpdateValidationResult updateValidationResult = issueService.validateUpdate(user, issue.id, issueInputParams) if (!updateValidationResult.isValid()) { log.error("Validation errors while updating issue: ${updateValidationResult.errorCollection}") return } else { def updateResult = issueService.update(user, updateValidationResult, EventDispatchOption.ISSUE_UPDATED, false) if (!updateResult.isValid()) { log.error("Update failed: ${updateResult.errorCollection}") } } }
For this example, I've set it to dispatch an IssueUpdated event, but not to send mail on the update. You may adjust those parameters, depending on your needs.
Your code seems to be correct. Is it placed after create issue postfunction?
Yes tried placing it after the create issue post function, but still does not work.
Try this code. Main idea - an Option object should be used to update value
import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.customfields.manager.OptionsManager import com.atlassian.jira.issue.customfields.option.Option import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.issue.fields.config.manager.FieldConfigManager if(issue.issueTypeObject.name != "ABC") return; CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); CustomField customerPriority = issue.getCustomFieldValue(customFieldManager.getCustomFieldObject("customfield_12345")); OptionsManager optionsManager = ComponentAccessor.getOptionsManager(); FieldConfigManager fieldConfigManager = ComponentAccessor.getComponent(FieldConfigManager.class) for(Option option: optionsManager.getOptions(fieldConfigManager.getFieldConfig(issue.getId()))){ if(option.getValue().equals("XYZ")) { issue.setCustomFieldValue(customerPriority, option) break; } }
There seems to be an issue in this part of the above code:
for(Option option: optionsManager.getOptions(fieldConfigManager.getFieldConfig(myIssue.getId()))){
if(option.getValue().equals("Project")) {
break;
Does this code work?
Do you get any errors?
I get an error for this line:
Error message:
java.lang.NullPointerException at com.atlassian.jira.issue.fields.config.persistence.FieldConfigPersisterImpl.getFieldConfig(FieldConfigPersisterImpl.java:193) at com.atlassian.jira.issue.fields.config.manager.FieldConfigManagerImpl.getFieldConfig(FieldConfigManagerImpl.java:33) at com.atlassian.jira.issue.fields.config.manager.FieldConfigManager$getFieldConfig.call(Unknown Source) at Script85.run(Script85.groovy:27)
I tried the following code, there is no error, but it is not updating the Custom Field.
What am I missing:
import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.customfields.manager.OptionsManager import com.atlassian.jira.issue.customfields.option.Option import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.issue.fields.config.manager.FieldConfigManager if(issue.issueTypeObject.name != "ABC") return; CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); def customerPriority = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("Priority"); def cfConfig = customerPriority.getRelevantConfig(issue); def value = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find { it.toString() == 'XYZ' } issue.setCustomFieldValue(customerPriority,value); issue.store();
Do not use issue update in code. It is bad practice. Make sure that you have "Store issue into database" build-in postfunction after your script postfunction.
Tried it, but does not work.
Also I tried to run the following code in 'Script Console' of script-runner, but does not update the value of the Custom Field:
import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.Issue; import com.atlassian.jira.issue.MutableIssue; import com.atlassian.jira.issue.IssueManager; import com.atlassian.jira.ComponentManager; import com.atlassian.jira.issue.resolution.Resolution; import com.atlassian.jira.issue.customfields.manager.OptionsManager; import com.atlassian.jira.issue.customfields.option.Option; import com.atlassian.jira.issue.fields.CustomField; import com.atlassian.jira.issue.fields.config.manager.FieldConfigManager; IssueManager issueManager = ComponentManager.getInstance().getIssueManager(); MutableIssue myIssue = issueManager.getIssueObject("JJJ-98765") if(myIssue.issueTypeObject.name == "ABC") { CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); def customerPriority = customFieldManager.getCustomFieldObjectByName("customfield_12345") def cfConfig = customerPriority.getRelevantConfig(myIssue); def value = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find { it.toString() == 'XYZ' } myIssue.setCustomFieldValue(customerPriority,value); myIssue.store(); }
Can you provide a piece of code that works well in your script-console?
You use myIssue variable instead issue. Also you get issue with specified issue key. Issue.store() is depricated. Do not use it. Never.
See updated code (I refactored it a litle)
import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.MutableIssue; import com.atlassian.jira.issue.IssueManager; import com.atlassian.jira.ComponentManager import com.atlassian.jira.issue.fields.CustomField; IssueManager issueManager = ComponentManager.getInstance().getIssueManager(); //Is it requared here? MutableIssue issue = issueManager.getIssueObject("JJJ-98765") if(issue.issueTypeObject.name != "ABC") return; CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); CustomField customerPriority = customFieldManager.getCustomFieldObjectByName("customfield_12345") def cfConfig = customerPriority.getRelevantConfig(issue); def value = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find { it.toString() == 'XYZ' } issue.setCustomFieldValue(customerPriority,value);
Used 'myIssue' only when running it in 'Script Console' on a particular issue.
Tried the above code, but does not update the value of the Custom Field for 'JJJ-98765'.
There are no errors, the 'value' is also taking the correct option, it is jut not setting the Custom Field.
can you post the actual script you are using
for a post-function that's first in the list, you just need:
issue.setCustFieldValue...
Don't redefine issue, or get it from the db, or call .store.
Jamie,
This is my actual script:
import com.atlassian.jira.component.ComponentAccessor; import com.atlassian.jira.issue.CustomFieldManager; import com.atlassian.jira.issue.customfields.manager.OptionsManager import com.atlassian.jira.issue.customfields.option.Option import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.issue.fields.config.manager.FieldConfigManager if(issue.issueTypeObject.name != "Bug") return; CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager(); def customerPriority = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("Priority"); def cfConfig = customerPriority.getRelevantConfig(issue); def value = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find { it.toString() == 'Project' } issue.setCustomFieldValue(customerPriority,value); log.warn(customerPriority) log.warn(value)
And I get the following values in my log file:
'log.warn(customerPriority)'= Priority
'log.warn(value)'= Project
Its just not updating this value on the JIRA ticket when the ticket is created.
I am using the following versions:
JIRA - 6.4.6
Scriptrunner - 3.1.4
The above post-function is being used in the 'Create Transition' of the workflow and placed after 'Creates issue originally'
Purpose of the script:
When a ticket is being created, if the issue type is 'Bug', the 'Priority' custom field, which is a single value select list should take the value 'Project'.
In short for issue type Bug, the 'Priority' Custom Field should automatically have the value 'Project' when the ticket is created.
Rupa
There is a bug for create transition. Postfunction to store changes do not work correct. So it is better to add manually store changes, like this:
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.event.type.EventDispatchOption; import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.issue.UpdateIssueRequest import com.atlassian.jira.issue.fields.CustomField; if(issue.issueTypeObject.name != "Bug") return; CustomField customerPriority = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("Priority"); def cfConfig = customerPriority.getRelevantConfig(issue); def value = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find { it.toString() == 'Project' } issue.setCustomFieldValue(customerPriority, value); log.warn(customerPriority) log.warn(value) ComponentAccessor.getIssueManager().updateIssue( ComponentAccessor.getJiraAuthenticationContext().getUser() , issue , UpdateIssueRequest.builder().eventDispatchOption(EventDispatchOption.ISSUE_UPDATED).sendMail(false).build() )
hi all
hi @Rupa Jain
Did you find a solution for this?
I am facing similar issue on updating s select list on create transition.
I have observed one strange behavior:
If i put the custom script transition at first position in post functions then log.warn(issue) gives value of summary of ticket in logs and does not update the select list value.
However when i make it second then it prints the relevant issue key but still does not update the select list value.
I want to set a select list value (Portfolio)based on value of second select list(Business Area) and then assign the ticket based on value of second select list.
Please bear with me on rookie way of coding!
JIRA 6.4.13
Script Runner: 4.1.3.29
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.customfields.option.Options
def userManager = ComponentAccessor.getUserManager()
String myUserName
User usr
def issueManager = ComponentAccessor.getIssueManager();
User currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
//Set Issue Type to SR_Service Request
def newIssueType = ComponentAccessor.issueTypeSchemeManager.getIssueTypesForProject(issue.projectObject).find{it.name=="SR_Service Request"}
if (newIssueType) issue.setIssueTypeObject(newIssueType)
def BusinessAreaCf = customFieldManager.getCustomFieldObjectByName("Business Area")
def BusinessArea = issue.getCustomFieldValue(BusinessAreaCf)
log.warn("Busines Area value is : "+BusinessArea)
log.warn("issue object is :"+issue)
def reqPortfolioCf = customFieldManager.getCustomFieldObjectByName("Portfolio")
def fieldConfig = reqPortfolioCf.getRelevantConfig(issue)
def reqPortfolio
if(BusinessArea != null)
if(BusinessArea.toString() == "Enterprise")
reqPortfolio = ComponentAccessor.optionsManager.getOptions(fieldConfig)?.find {
it.toString() == 'EBU'
println("portfolio is "+reqPortfolio)
issue.setCustomFieldValue(reqPortfolioCf, reqPortfolio)
log.warn(reqPortfolio)
log.warn(reqPortfolioCf)
, issue
, UpdateIssueRequest.builder().eventDispatchOption(EventDispatchOption.ISSUE_UPDATED).build()
else if(BusinessArea.toString() == "Finance")
it.toString() == 'FIN'
, issue
else if(BusinessArea.toString() == "Customer")
it.toString() == 'CBU'
, issue
//" Based on Portfolio field update Assignee field
//" We just need three cases for Portfolio: 'Cable Reporting', 'NGC', 'Enterprise, Finance, Consumer Mobile'
if (reqPortfolio) {
if (reqPortfolio.toString() == "CBU") {
if(issue.components*.name.contains('TSSC-DataProv'))
myUserName = "BICC.TSSC-DataProv"
println("Username is : "+myUserName)
else
myUserName = "BICC.CBU-Reporting" // BICC.CBU-Reporting@vodafone.com
else if (reqPortfolio.toString() == "FIN") {
myUserName = "BICC.Finance-Reporti" // BICC.Finance-Reporting@Vodafone.com
else if (reqPortfolio.toString() == "EBU") {
myUserName = "BICC.EBU-Reporting" // BICC.EBU-Reporting@vodafone.com
else if (reqPortfolio.toString() == "CBU-fixed")
// set aggignee
usr = userManager.getUserObject(myUserName)
issue.setAssignee(usr)
Output==>
2018-08-22 17:50:50,383 http-bio-8050-exec-56 WARN admin 1070x49299x1 dgqcse 10.74.207.7,139.7.95.77 /secure/QuickCreateIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Busines Area value is : [Finance]
2018-08-22 17:50:50,384 http-bio-8050-exec-56 WARN admin 1070x49299x1 dgqcse 10.74.207.7,139.7.95.77 /secure/QuickCreateIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] issue object is :SR-1579
Hi Bhupesh,
The following script worked for me (placed it before 'Creates Issue' post function):
return;
def SomeCustomField = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("XYZ");
def cfConfig = SomeCustomField.getRelevantConfig(issue);
it.toString() == 'SomeValue'
issue.setCustomFieldValue(SomeCustomField,value);
Rupa
