i found some luck in creating user in JIRA using groovy runner .here i mention my code .can you pls tel me whether it is correct or need to modify .because it throws error while running the script .
code:
import com.atlassian.jira.bc.user.UserService
def userService = ComponentAccessor.getComponent(UserService)
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
UserService.CreateUserValidationResult newValidUser =UserService.validateCreateUserForAdmin("p1247", "12025", "12025", "12025", "12025@ramco.com", "vijaya bhaskar v")
another code:
UserService.CreateUserValidationResult newValidUser =UserService.validateCreateUserForAdmin(currentUser, "12025", "12025", "12025", "12025@ramco.com", "vijaya bhaskar v")
error throws:
groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.bc.user.UserService.validateCreateUserForAdmin() is applicable for argument types: (com.atlassian.jira.user.DelegatingApplicationUser, java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String) values: [P1247(p1247), 12025, 12025, 12025, 12025@ramco.com, vijaya bhaskar v] at Script250.run(Script250.groovy:6)
hi ,
I used that also . i found error with that .
code:
final CreateUserRequest createUserRequest = CreateUserRequest.withUserDetails("abc","abc", "abc", "abc@gmail.com", abc)
result = userService.validateCreateUser(createUserRequest);
if(result.isValid())
userService.createUser(createUserRequest);
error:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script270.groovy: 7: unable to resolve class CreateUserRequest @ line 7, column 25. final CreateUserRequest createUserRequest = CreateUserRequest.withUserDetails("abc","abc", "abc", "abc@gmail.com", abc) ^ 1 error
It should be
UserService.CreateUserRequest createUserRequest = UserService.CreateUserRequest. withUserDetails(currentUser, "username", "password", "user@example.com", "Test User: user") UserService.CreateUserValidationResult result = userService.validateCreateUser(createUserRequest)
Thanks Thanos ..
Its working fine now..
can you please guide me to learn groovy script for JIRA .can you provide any documents to learn groovy for JIRA .
Learning groovy (a programming language very similar to Java) is one thing and writing groovy-scripts (using SR) for JIRA is another. For the latter, SR documentation has a lot of example scripts and is a great starting point, and of course Atlassian Answers...
Hi Thanos ,
is there any possibility to map a new user into groups while creating the new user login .
on top of my head, it should add something like that
if(result.isValid()) { def newUser = userService.createUser(result) def groupManager = ComponentAccessor.getGroupManager() def developersGroup = groupManager.getGroup("group-name") groupManager.addUserToGroup(newUser, developersGroup) }
Here is my code :
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
withUserDetails(user, "ASDASDF", "AASDSDFA", "ASDASAFA@gmail.com", "ASDASAA")
def developersGroup = groupManager.getGroup("IMG USERS")
print newUser
print developersGroup
else
result.getErrorCollection()
note :it creates the user and also map to the group also .but in result tab shows as null .
how can i print the username
while creating the new user before it results with username .but now it shows as null while creating and mapping a new user to a group .
i used print statement also .but no luck in this .
can you help me to short out of it .
you should add
return newUser.getDisplayName()
just after the groupManager.addUserToGroup(newUser, developersGroup). Also notice that in order to get debug (or error, or info) messages in your logs the way is
log.debug("This is a debug message that will appear in you atlassian-jira.log file")
It's deprecated Since v7.0. Use validateCreateUser(CreateUserRequest)
instead.
https://docs.atlassian.com/jira/latest/com/atlassian/jira/bc/user/UserService.html
