scriptrunner behaviour does not work proprely
Olivier October 16, 2016
Hello, I've done a script in scriptrunner behavior and it works only on the opening screen.
My script is to mandatory a customfied if an another customfield has the "1 - Very high" value...very simple
def infoprio = getFieldById("customfield_11002")
def impact = getFieldById("customfield_12404").getValue()
if (impact == '1 - Very Hight'){
    infoprio.setRequired(true)
else
    infoprio.setRequired(false)
A the opening of the screen the script is OK but when I try to change the value of the impact fiedl (a list) it does not work, nothing hapens.
Is there somebody have an idea ?
Olivier October 24, 2016
Sure...my problem was that I wasn't on the good field behaviour.
The script is good but I wasn't on the customfield_12404 behaviour, the field I would like to watch.
JamieA
October 17, 2016
Possibly typo of "1 - Very hight" ?
I see you asked and resolved the same question on our support portal, perhaps you could share the solution here.
