splitting jira instances, and maintaining issue links
Bryan Karsh
February 7, 2013
Okay, here's a fun one:
I am going to be splitting my jira instance into 2 instances -- with different projects in each instance. I want to somehow maintain existing issue links between projects that are now in different instances.
I know you can create cross-instance issue links, but is there a way to convert pre-existing links into cross-instance links? Other than running some Jira CLI or DB query, and updating the link information into some indexable field, I can't find an obvious way to do this.
Any suggestions?
Renjith Pillai
February 8, 2013
There is something coming soon. Check https://jira.atlassian.com/browse/JRA-5843
Email Roy as mentioned in that issue, if you are interested.
Bryan Karsh
February 8, 2013
Thanks Renjith!
Daniel Borcherding
November 7, 2013
How does archiving help maintain issue linkw when federating your Jira instnaces?
lenzai
February 17, 2013
Is there any plan to support splitting instances for JIRA OnDemand ?
I am running a project for a customer using now 7 users, He plans moving on with his dedicated instance. Can I just export the project and import in a new instance ?
