start button not visible when try for start sprint, after all user stories successfully copied
amrendra nath Srivastava
September 30, 2022
In a project trial, start button not visible when try for start sprint, after all user stories successfully copied.
Alex Koxaras -Relational-
Hi @amrendra nath Srivastava and welcome to the community!
Most likely you are missing the "Manage Sprints" permission. If you are the jira admin go to:
  • project settings
  • permissions
  • see which roles have that permissions and
    • either add your self to that permission
    • or add yourself to one of the available roles which grants this permission
October 3, 2022
Thanks Alex, for helping me, my problem is solved. As I updated sprint backlog story pointing and checked permissions required.
raj-kumar2
You are missing Start/Complete Sprints Permission. Please check and get it fixed under Permissions.
Fabio Racobaldo _Catworkx_
Hi @amrendra nath Srivastava ,
welcome to the Atlassian community!
Please check that you have Manage Sprint permission on the related permission scheme of your project
Hope this helps,
Fabio
FREE
