Is it possible to synchronize JIRA issues between two different jira cloud and jira server projekt?
Hello @farah sarraf
Yes this is possible.
There are a few add-ons that can help with that. Here are just two from those available. Note I have not used either.
Very much possible!
As Trudy correctly pointed you to a number of different addons that can achieve the integration of a Jira Cloud with Server, but the correct choice of connectors depends on what exactly you are trying to achieve. How complicated is the use case? What is the ticket volume? What fields would you like to sync across? Are there mapping involved?
I work with the Exalate team and would love to take this conversation forward. Feel free to book a slot with our engineer to get a personalized demo for the product and to discuss your use case further.
Majid
Hi @farah sarraf, thanks for the question. This is Umer from K15t, creators of the Jira app "Backbone Issue Sync for Jira".
As mentioned before by @Trudy Claspill, you'd need an issue sync app, such as Backbone, to sync issues between two different Jira projects.
Using Backbone, not only can you sync Jira issues between Jira Cloud and Server projects, but you can also opt to sync other data such as comments, attachments, and project versions.
You can also manage the flow of information via uni- or bi-directional control settings and use customized access control settings to ensure foolproof data privacy.
In case you're interested in learning more, feel free to schedule a free demo
or try Backbone for free for the first 30 days!
@farah sarraf , hello! As Trudy mentioned, it is absolutely possible. In addition to the already mentioned options - feel free to check out ZigiOps here, at the Atlassian marketplace. 100% no-code, ZigiOps connects the systems bi-directionally, syncs them (in your case, the issues from the two Jira instances) & keeps them updated in real-time. If you want to see how ZigiOps works, do not hesitate to book an explanatory meeting with our tech team.
Regards, Diana (ZigiOps team)
Hi @farah sarraf
As Trudy already mentioned there are a couple of 3rd party add-ons that allow synchronizing Cloud and Server instances. I work for a team developing Issue Sync for Jira which automatically creates issues, synchronizes fields, comments, and attachments between hostings, and keeps them updated.
If that sounds interesting to you feel free to try the app or boom a free demo session via Calendly.
Best regards,
Kasia from Deviniti
