×Hello,
this is driving me crazy. I created a post script function on the create transition, so that issues of one kind (you'll see in the screeshot) would be closed automatically after create (this is used for imported issues from another system, that have been already handled). The fast-track doesn't work under any circumstances. I tried almost everything. Attached you may find more info.
Best
Pujan
Post Function - Fast Track.pngScript Post Function - Fast Track.pngworkflow transitions.png
Does this mean it should be
cfValues[
"Message Source"
]?.value ==
"EFDIS"
Yes, it should be that. The stack trace doesn't affect anything functionally, it should still work fine.
The stack trace is an outstanding issue that should be fixed in the next version.
Your condition should be:
cfValues["Message Source"]?.value == "EFDIS"
Validator examples are at https://scriptrunner.adaptavist.com/latest/jira/recipes/workflow/validators/simple-scripted-validators.html#_validating_a_multi_select_option_is_selected.
btw I see this exception when I'm adding the condition, but I don't think it's relevant:
2016-02-08 14:49:35,679 http-bio-8080-exec-16 ERROR pziaie 889x764492x1 16j9kjc 192.168.159.97,127.0.0.1 /rest/scriptrunner/latest/canned/com.onresolve.scriptrunner.canned.common.StaticCompilationChecker [common.error.jersey.ThrowableExceptionMapper] Uncaught exception thrown by REST service: Could not initialize class com.onresolve.scriptrunner.runner.stc.ScriptCompileContext$ContextByName
java.lang.NoClassDefFoundError: Could not initialize class com.onresolve.scriptrunner.runner.stc.ScriptCompileContext$ContextByName
at com.onresolve.scriptrunner.runner.stc.ScriptCompileContext.fromLabel(ScriptCompileContext.groovy:86)
at com.onresolve.scriptrunner.runner.stc.ScriptCompileContext$fromLabel.call(Unknown Source)
at com.onresolve.scriptrunner.canned.common.StaticCompilationChecker.getContextFromParams(StaticCompilationChecker.groovy:81)
at com.onresolve.scriptrunner.canned.common.StaticCompilationChecker$getContextFromParams.callCurrent(Unknown Source)
at com.onresolve.scriptrunner.canned.common.StaticCompilationChecker.doScript(StaticCompilationChecker.groovy:103)
