I have problem with the jira board project.
there are problems loading
could you please fix it?
regards
@Veronica Andolfi, on a free cloud plan, your support is limited to asking questions to the community. we are not Atlassian support and cannot fix actual bugs in the system. We can offer advice and recommendations.
Is there an actual error being thrown on the page or in the web console logs?
Hi @Veronica Andolfi ,
If you are using a JIRA Cloud instance please raise a ticket with Atlassian Support.
Link: https://support.atlassian.com/
If you are using an on-prem instance contact your IT Support team.
