Hi
I'm looking for a way to show the total sprint point per user in a specific project, idk if there's a quick way to get this info instead of looking in all sprints individually
Hi @Aymane jilali ,
If you use Jira Cloud, you should search for the required work item using JQL. Then, include assignee and story points in your search as columns, and export the result for the possibility to filter them by assignee.
Here is an article on this topic:
https://support.atlassian.com/jira/kb/track-sprint-story-points-by-assignee-in-jira-cloud/
Thanks @Daria Kulikova_GitProtect_io
I did exactly what you mentioned, but instead of exporting the result and filtering it, I can get it directly by clicking "View work items as a chart."
I can switch the assigned user for quick results.
Hi @Aymane jilali,
This is not possible with the Jira native tools, but could search for an app / plugin on Atlassian Marketplace that supports such calculations/stats.
In case you want to try a plugin, our Great Gadgets app offers a Pivot Table & Pivot Chart gadget that lets you calculate and display this info on a Jira dashboard with just a few clicks. The data will be in real-time, so no need to export or to spend time with all kind of exports and manual calculations.
The info can be displayed as a table, heat-map table or charts of various types.
To get a table like that, the gadget should be configured like this:
If you have questions or need any help, feel free to contact support@stonikbyte.com.
Danut.
