track leadtime bugs in a project
Ralph Pierik
May 1, 2024
Is there an app in the dashboard to track the leadtime for bugs from an epic?
Valeriia_Havrylenko_SaaSJet
Hi @Ralph Pierik  👋
Time in Status is here to help you!
To track Jira Lead Time for bugs from in a epic, just simply:
  1. Filter your issues by type (Bugs)
  2. Set your report by epic and choose the one you need
  3. Create a Lead Group with specific statuses
Add-on has 30-day free trial version, free for up to 10 users and developed by SaaSJet.
Hope it helps 😌
Amay Purohit_RVS
May 1, 2024
Hi @Ralph Pierik
Welcome to the community !!
If you are fine to try out mktplace app, take a look at
Time in Status Reports
The app allows you to group your statuses to define your own lead / cycle times. Also the app has 20+ reports to meet a variety of use cases.
You can also add the app as a dashboard gadget.
Hope this helps.
More details here
The app is free for 10 users. Do try it out.
Disclaimer : I work for RVS, the vendor for this app
Gizem Gökçe (OBSS)
Hello @Ralph Pierik ,
Welcome to the community!
In order to track leadtime for bugs in an epic, Timepiece - Time in Status for Jira , the oldest and leading "Time in Status" app in Atlassian Marketplace, which is developed by my team at OBSS, has a report type that will meet your need.  Our app is available for both Jira Cloud, and Data Center. Time in Status reports can be accessed through its own dashboard gadgets.
Status Duration report  which shows how much time each issue spent on each status. You can combine the time for multiple statuses to get metrics like Issue Age, Cycle Time, Lead Time, Resolution Time etc. For all numeric report types, you can calculate averages and sums of those durations grouped by the issue fields you select.
For example lead time per issue type which are linked under specific epics as you requested.(please see the screenshot above)
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well.
Visit Timepiece - Time in Status for Jira to explore how our JIRA add-on can revolutionize your metrics measurement process. Enjoy a 30-day free trial to experience the full range of features.
If you wish, you can also schedule a live demo. We will provide a comprehensive overview of the application and address any inquiries you may have.
Hope it helps,
Gizem
Mehmet A _Bloompeak_
Hi @Ralph Pierik
There is no built-in solution for lead time reports in Jira. If you prefer to use a marketplace app, you can try Status Time Reports app developed by our team. It mainly provides reports and gadgets based on how much time passed in each status.
Here is the online demo link, you can see it in action and try without installing the app. For your case, you can have a look at Lead Time for Each Issue report.
For further details, you can have a look at Cycle Time and Lead Time in Jira: Productivity Measurement with Two Critical Parameters article and Status Time Reports How to Videos.
  • This app has a dynamic status grouping feature so that you can generate various valuable reports as time in status, time in assignee, status entry dates and status counts, cycle time and lead time, resolution time, average/sum reports by any field(e.g. average in progress time by project, average cycle time by issue creation month).
  • You can search issues by Project, Issue Type, Status, Assignee, Issue Creation/Resolution Date(and any other Date field) and JQL Query.
  • Status durations are calculated according to the working calendar you define. Once you enter your working calendar into the app, it takes your working schedule into account too. That is, "In Progress" time of an issue opened on Friday at 5 PM and closed on Monday at 9 AM, will be a few hours rather than 3 days.
  • You can set different duration formats.
  • You can export reports in CSV file format and open them in MS Excel.
  • You can also add this app as a gadget to your Jira dashboards and reach “Status Time” from Issue Detail page.
  • You can enable/disable access to Status Time reports&gadgets and Issue Detail page per project, users, groups or project role.
If you are looking for a completely free solution, you can try the limited version Status Time Reports Free.
If you have any questions, feel free to schedule a demo with us.
Hope it helps.
