Does anyone know how I can change the trial jira account interface from Simplified Chinese to Traditional Chinese or SC to English?
Thanks.
There are a few steps you will need to take to adjust your language within Jira cloud. Those steps are as follows:
Jira productsBy default, Jira Cloud will use the language set by your user's browser. The language you set here will be the language Jira Cloud will display in, if it can't detect the browser's language. This can be overwritten by the individual user, if they've selected a language setting in their profile (see Language settings for individual users below).
- Choose Settings > System in the Jira sidebar
- Choose Edit Settings
- Select your Default language and choose Update.
Source document: Set the default language.
There are additional steps within that KB which also explain how to update the language for an individual user as well.
I hope this proves helpful and you’re able to adjust your language settings.
Stephen Sifers
Thanks for the answer. But no, I tried many times with that, it didn't work at all. My suggestion is that maybe you guys can try to set the default language to the language that the country actually uses or make the option available for the user to decide.
Thank you again.
Hello again,
Users are able to decide their language within the products. There are 2 shorts steps they will need to complete to change their language:
Additional information on language settings may be found at Set the default language
Stephen Sifers
