trying to upload issues into Jira Work Management getting error type 500 internal server error.
Brooks, Stephanie (CNE)
July 30, 2024
John Funk
Hi Stephanie - Welcome to the Atlassian Community!
Your image is not showing. Can you reload it? Also, can you share your spreadsheet you are using? At least the header and maybe first row.
Bhanu
July 30, 2024
Hi Stephanie,
Welcome to the community!
Can you give a little more context how you are trying to import issues and the environment from which you are doing the import? Are you trying to import it through CSV, JSON, Cloud, Server import feature?
