Our JIRA version is 5.1.4, when I use two dimensional filter statistics gadget, there's a custom field "Automated", the type is select list, it has 5 options:
but when I save, the two dimensional filter statistics only shows In Progress, Ready for Automation, No, None. Yes and Not Automatable doesn't show. Whatever I set "Automated" as XAxis or YAxis. And I can't find anywhere to show more columns. Does anyone know the reason?
The filter is
project = ABC AND issuetype = "Test Case" AND Keyword ~ "For ABC"
BTW, this field has many context, does this affect the gadget?
Thanks a lot
Thanks for Sy help. Just Sort options alphabetically. It's working.
Hi, It's working, I just click Sort options alphabetically. Thank you very much
Oh okay great! :
Heres a few things you can try to perhaps fix this issue:
Is it working for any other select list?
Have you tried moving the position of the value "Not Automatable" in the Customfield ? just a thought to give a try..
