two dimensional filter statistics does not show custom fields all options
Xiang Zhang May 13, 2015
Our JIRA version is 5.1.4, when I use two dimensional filter statistics gadget, there's a custom field "Automated", the type is select list, it has 5 options:
  • In Progress
  • Not Automatable
  • Ready for Automation
  • Yes
  • No
 but when I save, the two dimensional filter statistics only shows In Progress, Ready for Automation, No, None. Yes and Not Automatable doesn't show. Whatever I set "Automated" as XAxis or YAxis. And I can't find anywhere to show more columns. Does anyone know the reason?
The filter is
project = ABC AND issuetype = "Test Case" AND Keyword ~ "For ABC"
BTW, this field has many context, does this affect the gadget?
Thanks a lot
Thanks for Sy help. Just Sort options alphabetically. It's working.
Hi, It's working, I just click Sort options alphabetically. Thank you very much
Junaid Shah
May 13, 2015
Oh okay great! :
Junaid Shah
May 13, 2015
Heres a few things you can try to perhaps fix this issue:
  1. Delete the filter and add it again.
  2. Try the filter without any saved filters, and just the project.
  3. Try moving the value "Not Automatable" up or down the list within the custom field and see if it has any effect.
Is it working for any other select list?
Junaid Shah
May 13, 2015
Have you tried moving the position of the value "Not Automatable" in the Customfield ? just a thought to give a try..
