update issue field with issue key id
Hemant S February 20, 2017
We need to save the issue id in a custom field before we move the ticket over. So i added a script to save the issue id when a ticket gets created. Here is my script.
def custom_ticket_id = issue.getKey()
def cticketCf = customFieldManager.getCustomFieldObjectByName("Custom Ticket ID")
issue.setCustomFieldValue(cticketCf, "${custom_ticket_id}")
For some reason this does not populate the custom field. The script seems to run without errors. Is there something wrong with my script ?
Vasiliy Zverev
February 20, 2017
Your coe seems to be correct.
But when postfucntion is called? Is it aflter create issue one? Do you have "Save changes into database" postfucntion after it?
Hemant S February 21, 2017
Postfunction is called after the create issue. The last post function in the list.
How do i add "Save changes into database" postfunction ?
Vasiliy Zverev
February 21, 2017
Edit workflow - select transition - open postfunction section - press "Add post function" button - select "Stores updates to an issue".
I also would reccomend to use this code to store changes since it is compatible with JIRA 7:
issue.setCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Custom Ticket ID"), issue.getKey())
ComponentAccessor.getIssueManager().updateIssue(
        ComponentAccessor.getJiraAuthenticationContext().getUser()
        , issue
        , UpdateIssueRequest.builder().eventDispatchOption(EventDispatchOption.ISSUE_UPDATED).sendMail(false).build())
Hemant S February 22, 2017
works as exepected with the
        , issue
Stefan Arnold
February 20, 2017
Not sure i its really necessary but i think you have to use issueService to update the issue.
Iam using it in my scripts and everythink is working fine.
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import org.apache.log4j.Category
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.bc.issue.IssueService.UpdateValidationResult
import com.atlassian.jira.bc.issue.IssueService.IssueResult
import com.atlassian.jira.issue.IssueInputParameters
def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction")
log.setLevel(org.apache.log4j.Level.DEBUG)
IssueService issueService = ComponentAccessor.getIssueService()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
def user = ComponentAccessor.getJiraAuthenticationContext().loggedInUser
def optionsManager = ComponentAccessor.getOptionsManager()
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters()
CustomField customLieferant = customFieldManager.getCustomFieldObject(10046L)
CustomField customFreigabe = customFieldManager.getCustomFieldObject(10028L)
//def issue = issueService.getIssue(user, "WAR-17")?.issue
String lieferant = (String) issue.getCustomFieldValue(customLieferant)
def cfConfig = customFreigabe.getRelevantConfig(issue)
def optionTrue = ComponentAccessor.optionsManager.getOptions(cfConfig).getOptionForValue("True", null)
def optionFalse = ComponentAccessor.optionsManager.getOptions(cfConfig).getOptionForValue("False", null)
def changeHolder = new DefaultIssueChangeHolder();
def liefList = ['Test1', 'Test2']
log.debug("checkDistributor -> " + String.valueOf(issue) + " : Starte Lieferantenvergleich")
liefList.find{
        if (it == lieferant){
                log.debug(it + " gefunden in " + String.valueOf(issue));
                issueInputParameters.addCustomFieldValue(customFreigabe.id, optionFalse.getOptionId().toString())
                return true;
        log.debug("Lieferant: " + lieferant + " nicht in Liste")
        issueInputParameters.addCustomFieldValue(customFreigabe.id, optionTrue.getOptionId().toString())
        return false;
log.debug(issueInputParameters.getCustomFieldValue(customFreigabe.getId()).toString())
UpdateValidationResult update = issueService.validateUpdate(user, issue.id, issueInputParameters)
log.debug(user.toString())
if (update.isValid()){
IssueResult updateResult = issueService.update(user, update)
    if (updateResult.isValid()){
           log.debug("Updating " + issue.getKey() + " succesful")
    } else {
                log.debug("Error in issueService.update of " + issue.getKey())
} else {
    log.debug("Error in issueService.validateUpdate of " + issue.getKey() + ": " + update.getErrorCollection())
In my case i change radiobutton field but concept should be the same. Hope this helps.
Ok. I fixed it with ...
        ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
        ,issue
        , EventDispatchOption.ISSUE_UPDATED
        , false
But now i have an issue with the following error ..
2017-02-21 15:06:16,744 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: CM-419, actionId: 1, file: <inline script>
java.lang.ClassCastException: org.codehaus.groovy.runtime.GStringImpl cannot be cast to java.lang.String
	at com.atlassian.jira.issue.customfields.impl.GenericTextCFType.getDbValueFromObject(GenericTextCFType.java:51)
	at com.atlassian.jira.issue.customfields.impl.AbstractSingleFieldType.createValue(AbstractSingleFieldType.java:138)
	at com.atlassian.jira.issue.fields.CustomFieldImpl.createValue(CustomFieldImpl.java:731)
	at com.atlassian.jira.issue.fields.CustomFieldImpl.updateValue(CustomFieldImpl.java:448)
	at com.atlassian.jira.issue.fields.CustomFieldImpl.updateValue(CustomFieldImpl.java:434)
	at com.atlassian.jira.issue.managers.DefaultIssueManager.updateFieldValues(DefaultIssueManager.java:704)
	at com.atlassian.jira.issue.managers.DefaultIssueManager.updateIssue(DefaultIssueManager.java:669)
	at com.atlassian.jira.issue.managers.DefaultIssueManager.updateIssue(DefaultIssueManager.java:655)
	at com.atlassian.jira.issue.IssueManager$updateIssue.call(Unknown Source)
	at Script240.run(Script240.groovy:23)
JamieA
February 21, 2017
Somewhere you are using something
"$variable"
(ie a GString). Just add a .toString() after the string.
Ah. I was converting it outside. using .toString with the declaration fixed it. thanks
