updates of Jira
Nikita Shah July 8, 2019
can i update the jira core and software in new version?? will it affect the existing system or not?
jira.JPGcan you give me support how to upgrade the jira core and software in new vserion without affect of existing version.
Milan Chheda [INFOSYSTA]
July 8, 2019
Upgrading won't affect existing system. You can follow here for steps on upgrading JIRA server.
Here is the upgrade checklist: https://confluence.atlassian.com/adminjiraserver/upgrade-checklist-966063320.html
Few Important things:
  1. Have backups in place (of installation, home directory and database)
  2. Check the add-ons that are being used and see if they are compatible with JIRA 8.2.2
Nikita Shah July 9, 2019
thank you sir.
i should upgrade via installer?
can anyone help me??
