I upgraded to jira 6.2.2, now the app won't launch in a browser. The app is running per ps aux | grep java.
This is the bottom of atlassian-jira.log:
JIRA 6.2.2 build: 6258 started. You can now access JIRA through your web browser.
2014-04-15 13:26:28,972 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Setting current build number to 6258
2014-04-15 13:26:28,977 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Setting current version to 6.2.2
2014-04-15 13:26:28,979 localhost-startStop-1 INFO [atlassian.jira.upgrade.UpgradeManagerImpl] Setting downgrade version to 6.1.7
2014-04-15 13:26:30,529 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
Modified Files : jira-application.properties
Removed Files : None
2014-04-15 13:26:31,619 localhost-startStop-1 INFO [ext.bamboo.service.PlanStatusUpdateServiceImpl] Job 'com.atlassian.jira.plugin.ext.bamboo.service.PlanStatusUpdateServiceImpl:job' scheduled to run every 60000ms
2014-04-15 13:26:31,620 localhost-startStop-1 INFO [plugins.dvcs.scheduler.DvcsScheduler] DvcsScheduler start planned at Tue Apr 15 13:52:31 CDT 2014, interval=3600000
2014-04-15 13:26:31,664 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-taskboard-shortcut' was null. Not enabling.
2014-04-15 13:26:31,664 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-chartboard-shortcut' was null. Not enabling.
2014-04-15 13:26:31,664 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-releasedboard-shortcut' was null. Not enabling.
2014-04-15 13:26:31,675 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-delete-shortcut' was null. Not enabling.
2014-04-15 13:26:31,676 localhost-startStop-1 INFO [greenhopper.plugin.sampledata.JiraImportersPluginInstallerImpl] Checking if jira-importers-plugin is present and at version 4.4 or higher
2014-04-15 13:26:31,677 localhost-startStop-1 INFO [greenhopper.plugin.sampledata.JiraImportersPluginInstallerImpl] jira-importers-plugin already at 6.1.3.
2014-04-15 13:26:33,297 localhost-startStop-1 INFO [greenhopper.service.logging.LogSupport]
Managed Issue Types
Epic id=10000 name=Epic
Story id=10001 name=Story
Managed Custom Fields
Epic Colour id=customfield_10009 name=Epic Color type=com.pyxis.greenhopper.jira:gh-epic-color
Epic Link id=customfield_10006 name=Epic Link type=com.pyxis.greenhopper.jira:gh-epic-link
Epic Name id=customfield_10007 name=Epic Name type=com.pyxis.greenhopper.jira:gh-epic-label
Epic Status id=customfield_10008 name=Epic Status type=com.pyxis.greenhopper.jira:gh-epic-status
Default Global Rank id=customfield_10004 name=Rank type=com.pyxis.greenhopper.jira:gh-global-rank
Sprint id=customfield_10005 name=Sprint type=com.pyxis.greenhopper.jira:gh-sprint
Story Points id=customfield_10002 name=Story Points type=com.atlassian.jira.plugin.system.customfieldtypes:float
Managed Issue Link Types
Epic Link Issue Link Type id=10200 name=Epic-Story Link
2014-04-15 13:26:33,489 localhost-startStop-1 INFO [jira.whatsnew.listeners.WhatsNewUpgradeFinishedListenerImpl] Enabling show-whats-new-flag for all users
2014-04-15 13:26:33,493 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] Starting the JIRA Scheduler....
2014-04-15 13:26:33,505 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler started.
2014-04-15 13:26:35,069 QuartzScheduler_Worker-0 INFO ServiceRunner Backup Service [jira.bc.dataimport.DefaultExportService] Data export completed in 1389ms. Wrote 14509 entities to export in memory.
2014-04-15 13:26:35,070 QuartzScheduler_Worker-0 INFO ServiceRunner Backup Service [jira.bc.dataimport.DefaultExportService] Attempting to save the Active Objects Backup
2014-04-15 13:26:35,477 QuartzScheduler_Worker-0 INFO ServiceRunner Backup Service [jira.bc.dataimport.DefaultExportService] Finished saving the Active Objects Backup
2014-04-15 13:26:36,648 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteDirectory] synchronisation for directory [ 10000 ] starting
2014-04-15 13:26:37,356 CrowdUsnChangedCacheRefresher:thread-2 INFO [directory.ldap.cache.UsnChangedCacheRefresher] found [ 51 ] remote groups in [ 697ms ]
2014-04-15 13:26:38,165 CrowdUsnChangedCacheRefresher:thread-1 INFO [directory.ldap.cache.UsnChangedCacheRefresher] found [ 1265 ] remote users in [ 1505ms ]
2014-04-15 13:26:38,221 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 1265 ] users for delete in DB cache in [ 50ms ]
2014-04-15 13:26:38,221 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned for deleted users in [ 52ms ]
2014-04-15 13:26:38,224 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanning [ 1265 ] users to add or update
2014-04-15 13:26:38,238 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] scanned and compared [ 1265 ] users for update in DB cache in [ 17ms ]
2014-04-15 13:26:38,239 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] synchronised [ 1265 ] users in [ 18ms ]
2014-04-15 13:26:38,239 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] scanning [ 51 ] groups to add or update
2014-04-15 13:26:38,246 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 51 ] groups for update in DB cache in [ 7ms ]
2014-04-15 13:26:38,246 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] synchronized [ 51 ] groups in [ 7ms ]
2014-04-15 13:26:38,250 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 51 ] groups for delete in DB cache in [ 4ms ]
2014-04-15 13:26:38,617 QuartzScheduler_Worker-1 INFO [atlassian.crowd.directory.DbCachingRemoteDirectory] FULL synchronisation complete for directory [ 10000 ] in [ 1969ms ]
[jira@pros-jira log]$ ll
total 122768
-rw------- 1 jira jira 219501 Apr 15 13:26 atlassian-greenhopper.log
-rw------- 1 jira jira 16205992 Apr 15 13:26 atlassian-jira.log
-rw------- 1 jira jira 4370113 Apr 15 13:26 atlassian-jira-security.log
-rw------- 1 jira jira 20971523 Apr 14 14:22 atlassian-jira-security.log.1
-rw------- 1 jira jira 20971630 Apr 10 09:56 atlassian-jira-security.log.2
-rw------- 1 jira jira 20971647 Apr 6 06:26 atlassian-jira-security.log.3
-rw------- 1 jira jira 20971557 Apr 2 08:46 atlassian-jira-security.log.4
-rw------- 1 jira jira 20971582 Mar 29 07:26 atlassian-jira-security.log.5
-rw------- 1 jira jira 749 Mar 26 14:19 atlassian-jira-slow-queries.log
It looks to me like it's working, as it's syncing with our AD.
Is it possible that you forget to change running port in server.xml. Can you check localhost:8080 using lynx or links?
I believe it's a firewall issue
That was exactly the problem. We're doing an SSL off-load from our LB, so I'm using 443 -> 8443. The upgrade stepped on the server.xml file. I just had to uncomment it and add the SSL password and I was back in business.
Glad to have discovered this problem while we're still on an eval license, but I'll know what to look for the next time I upgrade Jira, and when I upgrade Confluence and Stash.
In general, I've been quite pleased with the ease of managing these products, but over-writing config files in an upgrade is not cool, Atlassian.
