I'm trying to use a simple curl request to get details of an issue but it is failing with
{"errorMessages":["Issue does not exist or you do not have permission to see it."],"errors":{}}
I'm using the following Curl request
curl -D- \
-H "Authorization: Basic base64encoded(emailaddress:APIToken)" \
-H "Content-Type: application/json" \
"https://<site-url>/rest/api/2/issue/TEST-1"
If I hit the same url in a browser it works fine.
When I look at my API token dashboard I can see that the last accessed field updates to "a few seconds ago" when I make the curl request. If I put in a wrong base64encoded value I get an HTML response.
This command worked for me on a brand new cloud site:
curl -D- --user emailaddress:apitoken https://mysite.atlassian.net/rest/api/2/issue/TEST-1
Maybe wrong email, invalid issue, or the Content-Type header is throwing things. Try with the --user switch
I think that you need to pass through a method of GET, although I don't know what the syntax is like because I've never used Curl
Thanks for the reply. It defaults to a GET by default. I've making it explicit but that also doesn't work.
