×What is the best way to import data into a SelectList using Jelly
For example we have build Numbers that could be in a selectlist. But Jelly seems to reference the items in the combobox/listbox by their IDs and not by their names. For example: Build number 7999 is referenced as “19209” and not just by 7999. Thus importing is a nightmare. is there a better way? Am I missing something?
Thanks for any help you can give
Nick
Only a nightmare because you did not follow the API and use IDs.
You could always create your own way to map the values to the IDs. I sure Jelly does not do that for you. But if you mean by methods other than Jelly, there's REST and SOAP.
