using jira-mobile-connect with a limited/unlimited # of accounts
Vickram J
January 15, 2012
Do we need to have an unlimited # of accounts on our JIRA install to use jira mobile connect?
Nick
January 16, 2012
Hi Veejayus,
JIRA Mobile Connect will consume exactly one user license. When you install the plugin and an issue is created, the jiraconnectuser is added to your JIRA instance. This user is then used as the 'Creator' of all issues created by mobile users.
So, to answer your question - you do not need an unlimited number of accounts in JIRA to use JIRA Mobile Connect.
Cheers - and keep us posted with how you go using JMC!
Nick Pellow
JMC Developer
Vickram J
January 17, 2012
Thanks Nick. We've wired up our app with JMC, it looks good so far!
