what is the difference between issues and Bugs ?
Prachi Pandey April 21, 2019
I am just confused between the issues and bugs
3 accepted
Ollie Guan
Hi @Prachi Pandey ,
Issue types are a JIRA concept and are the underlying objects for request types.Keep track of different types of issues, such as bugs or tasks. Each issue type can be configured differently.
Bug is a problem which impairs or prevents the functions of the product.
Prachi Pandey April 22, 2019
Thanks for your response.
Like Tomasz Sikorski likes this
Kurt Klinner
April 21, 2019
Ashkan Malekly
April 21, 2019
Hi prachi
Bug is a issue type.issues can be use as parent and child. Also bug can have parent and sub issue (as child). U can not find the different between them.bug is just a type of issues that is at the same level of story, task.
Cheers
