We are planning a JIRA upgrade to v6.1.7 and JIRA Show Saved Filter with Columns plugin is only compatible with JIRA 6.0.8. When will the compatible version be available?
Jozef, thank you for your suggestion. Didn't know about this and We are looking into that now.
Thank you Norman. Contacted the vendor and here's the reply.
Bryan,
We hope to release a new version early next week.
I would suggest you to use built-in Filter results (as it have this functionality at least from 6.0).
Please contact the vendor directly since this plugin was not updated on the marketplace to support 6.1.
