×Hi
We're trying to set-up our dev server as a single node.
We only have dev-node1 up and running and the cluster.properties has no node values. Until today we also had a dev-node2 running.
But the system still shows both nodes plus older node names. See image.
This doesn't appear to causing any functional issues but i'd like it to be accurate.
Any ideas
Tom
I discovered this info is coming from the clusternode db table
we started with a prod database copy hence the node1/node2 entries.
Would like to know if it's safe to clean up
As a side issue, I also found our dev and staging servers have been setup to share the same EFS area which was causing lots of weird stuff to happen
Odd behaviours was the main reason for trying to put into single node more
