why does my release burndown not work?
Janet Cerniglia March 21, 2017
Nic Brough -Adaptavist-
March 21, 2017
What is the config, what is it doing, and why do you think this is wrong?
image2017-3-21 17:23:58.png
March 21, 2017
Ok.  That's an easy one.  You have not put estimates on any issues that have that fix-version.
Actually, I can't even slect the release/version I want even though I see it in the the list.  And the the Jiras definitely have estimates with the correct fix version.
March 21, 2017
I'm not sure what "I can't select the thing I want" means.
  In your screenshot, you've selected "BW: NB 5.0" and discovered that you have not put estimates on any of the issues in that version.  How does that differ from what you are trying to select?
Danut M _StonikByte_
Try the Release Burndown Burnup Chart Gadget offered by the Great Gadgets add-on (see https://marketplace.atlassian.com/plugins/com.stonikbyte.great.gadgets.plugin/cloud/overview).
