why my calculated field does not always work correctly
tom webb November 18, 2015
I have a calculated field using javascript to calculate the number of workdays between created and resolved and works correctly most of the time however will sometimes calculate incorrectly. What is wrong here?
<!-- @@Formula: long days(Date start, Date end){
//Ignore argument check
Calendar c1 = GregorianCalendar.getInstance();
c1.setTime(start);
int w1 = c1.get(Calendar.DAY_OF_WEEK);
c1.add(Calendar.DAY_OF_WEEK, -w1 + 1);
Calendar c2 = GregorianCalendar.getInstance();
c2.setTime(end);
int w2 = c2.get(Calendar.DAY_OF_WEEK);
c2.add(Calendar.DAY_OF_WEEK, -w2 + 1);
//end Saturday to start Saturday
long days = (c2.getTimeInMillis()-c1.getTimeInMillis())/(1000*60*60*24);
long daysWithoutSunday = days-(days*2/7);
if (w1 == Calendar.SUNDAY) {
w1 = Calendar.MONDAY;
if (w2 == Calendar.SUNDAY) {
w2 = Calendar.MONDAY;
return daysWithoutSunday-w1+w2;
return days(issue.get("created"),issue.get("resolutiondate"))
tom webb November 22, 2015
it doesnt calculate the correct number of days on all issues sometimes it will show 1 day for something created today and solved 2 minutes later when it should be 0 and some show 9 days when it should be 5 days etc, others work perfectly so im not sure what the issue is.
Andreas Ebert
November 18, 2015
First, the formula uses Java, not JavaScript. Second, how exactly does it "sometimes calculate incorrectly"? We need more information in order to be able to help you.
Jamie Echlin _ScriptRunner - The Adaptavist Group_
This looks like JMWE plugin, not ScriptRunner.
