This filter works
worklogAuthor = currentuser()
This finds nothing
worklogAuthor = currentuser() AND worklogDate >= 2018-01-01 AND worklogDate <= 2018-12-31 ORDER BY Rank ASC
Work has been this year!
support had a look,
They suggest may have to with plugin from tempo
Hi Michael,
When work is logged in Tempo, the worklogs are stored in the Tempo database and the time spent on the issue is updated to JIRA. Therefore the worklogauthor function will not work for worklogs created with Tempo
(see also https://tempo-io.atlassian.net/wiki/spaces/TEMPO/pages/153419777/How+does+Tempo+integrate+with+the+Time+Spent+field+in+Jira).
Susanne Götz
Tempo team
Thank for feedback
Using cloud, what I can find is that re-indexing just happens- no option to run
Hi Michael,
The Cloud Support team can run a reindex for you, but you'll need to open a support ticket to request it.
My recommendation would be to open a ticket for this anyway, since they'll be able to look at your instance and work with the data you have in order to understand what the issue is.
Shannon
Hi @Michael Killeen,
Welcome to this community :)
In my company Jira instance, the last filter works fine, is your Jira instance fully reindex?
Adrián.
